Max HP from a stock 454/502 Carb Intake >
Old 02-19-2006 | 02:16 PM
Default Max HP from a stock 454/502 Carb Intake
What is the max HP that can be made with a stock 454/502 aluminum carb intake manifold? I want to be able to make at least 500 HP on my rebuild. I'm probably going to go with Iron Eagle Heads. Should I scrap the stock manifold and go with something better or will the stock manifold do fine.
IHTFP is offline
Old 02-20-2006 | 08:36 AM
Pat McPherson's Avatar
Default Re: Max HP from a stock 454/502 Carb Intake
Most people go with a single plan intake for 500+HP.
You probably can reuse the dual plane if you add a 1" open spacer and port match to the heads...
Patrick
Pat McPherson is offline
Old 02-20-2006 | 08:44 AM
check out Crockett marine, they have a upgrade kit that gets you 100 + HP!!
powerquest 380 is offline
articfriends
38
02-28-2014 09:18 AM
Rocko C
4
07-24-2007 11:41 AM
Formula29
2
04-17-2004 01:20 AM
Keith
9
06-01-2003 10:08 PM
FWK
11
03-01-2003 05:51 PM
