What would you like to see Baja build?
What would YOU like to see Baja build or do that they currently don't?
Me. I'd like to see a really fast v-bottom with wild non-merc power.
I'd also like to see a twin engine cat with, shocker - Big power.
Originally Posted by Dock Holiday
38 Foot v-hull, 4-man poker run cockpit, no cuddy, under 9000 lbs w/ Merc 700SC's and a LOT of room in the engine compartment.
That, and a 41-42 along the same lines.
Yea, the PR boat would be cool if it was built right. I like the 40-42 foot idea.
Baja was on the right track with that 40 Outlaw with the 1075SCI's in it, but it needed some refinement speed department.
Isn't Baja owned by Brunswick? Same as Mercury?
Probably not going to see many boats w/o black & blue motors. Also didn't they start the process for a "fast" V and then back off, IE the 399 Baja-Skater?
That boat got a good home with Skater. Skater did it right though.
Originally Posted by JasonSmith
Yea
That boat got a good home with Skater. Skater did it right though.Skater designed and built it.
Baja's plan was ( for the most part) to market it.
