100 in a 35 (maybe) >
100 in a 35 (maybe)
100 in a 35 (maybe)
Old 02-22-2006 | 07:21 PM
TeamSaris's Avatar
Driver-441
Racer
Default 100 in a 35 (maybe)
It might go 100. The motors should make 750 easy.
Attached Thumbnails 100 in a 35 (maybe)-fountain1-small-.jpg   100 in a 35 (maybe)-fountain2-small-.jpg   100 in a 35 (maybe)-fountain3-small-.jpg
TeamSaris is offline
Old 02-22-2006 | 07:24 PM
TeamSaris's Avatar
Driver-441
Racer
Default Re: 100 in a 35 (maybe)
Some more.
Old 02-22-2006 | 07:44 PM
Rebel_Heart's Avatar
Good luck with your attempt at 100 mph. Let us know how that goes. I won't have quite that much hp - but somewhere close. Are you doing anything special with your drives?
Rebel_Heart is offline
Old 02-22-2006 | 08:44 PM
Beak Boater's Avatar
Charter Member # 545
Fast Fun 2
Good Luck, you will be close. Are those Whipples on stock 500's or did you do some work to them? Had a set of Whippled 500's in a 35 Lightning. It ran 100 once, 95-98 a bunch. Went back and built a set of 540's then I had no problem reaching over the century mark. What ever speed you are running now add 10-12 mph with the Whipples. If the motors are stock.
Randy
Beak Boater is offline
Old 02-22-2006 | 10:40 PM
jryan26's Avatar
At 750 you should be there talk to Mav35 He is around 110 in a 1997 35.
Jonas has a twin step and is running 100+ also.
jryan26 is offline
Old 02-22-2006 | 10:46 PM
Beak Boater - I see you had 540's. Where these NA? What hp were you turning? What drives did you go with? Thanks.
Old 02-22-2006 | 11:45 PM
Lightning or Executioner?
Fanatic is offline
Old 02-23-2006 | 07:11 AM
540's where Whippled, AFR Heads, Crane 731 cam. Started with Bravo's bought a pair of IMCO SC's. Both IMCO's had problems around 40 hrs. Rebuilt them both and got over 100 hrs on them. They were standard length not shorties. If I did it again, I think I would go Mercury xr. No warranty on IMCO's plus they are in Calif. If you have a problem and you want them to work on them you have to send them back to them. They are begining to have a small dealer network you should check with IMCO and find out if someone in your area deals with them. At least with Mercury you do have some warranty. Good luck..If you have any questions, I went down this road before I will try to answer them.
Old 02-23-2006 | 08:33 AM
Sweet
Marginmn is offline
Old 02-23-2006 | 08:36 AM
TeamSaris's Avatar
Driver-441
Racer
Lightning. It is a 02'. Will take more pics today.
