Mph increase question
Another 120HP more should give you a 8-9mph increase.
You said your 200/305 is tired so a fresh 320HP should give you more.
I know of two boats similar to yours running in the 50s with the new 325HP/350 vortec engines.
A 1984 20' Liberator and a 1989 205 Formula. The Formula has touched 60 a time or two but that boat is likely lighter than yours.
Patrick
Patrick
Are you sure that boat only weighs 2700 lbs? My 20 ft Malibu inboard ski boat weighs 2700. However it has a hull and drivetrain made for pulling and only a 260hp engine and it would go 47 when it was new. I'd guess right around 50 for the new engine.
My 1987 20' Donzi Minx weighed in at about 2700 dry. That boat would run well over 60mph with a 270HP/350.
My friend's Formula 205LS weighs in at about 3300 dry and has touched 60 with a new 325HP/350.
Woody, if your boat does really only weighs 2700, it will run close to 60 with a 320HP. But my guess is that it weighs at least 800lbs more than that...
Patrick
Patrick
Originally Posted by Pat McPherson
Good Point...
