Seawater Strainers >
Seawater Strainers
Seawater Strainers
Old 02-26-2006 | 09:30 PM
Default Seawater Strainers
Hey... someone should warn us... 525 freshwater cooled should always... always have seawater strainers!
The salt water passes through three heat exchangers that are just very small copper tubes. The least bit of seaweed or debris will clog them. Then it's a long hard job to get them cleaned out again. I learned the hard way!
Now I need a recommendation on sea water strainers. While I'm putting them in, I would like to have a cool color... maybe blue to match the 525's?
Who makes some good ones that are easy to sight when clogged and easy to clean out?
Thanks for any recommendations... JON
Jnewton is offline
Old 02-26-2006 | 09:34 PM
betitbig's Avatar
Default Re: Seawater Strainers
Does the 525 have the same closed cooling system as the 496's ? If so do 496's need them as well? I have been wondering this myself.
betitbig is offline
Old 02-27-2006 | 07:24 AM
Yes. Antifreeze runs through the engine and the salt water runs through these tiny little tubes in three different heat exchangers that get clogged up very easily... And they are a bear to clean out. I spent all day yesterday in the engine compartment.
JON
Jnewton is offline
Old 02-27-2006 | 09:50 AM
Wobble's Avatar
SORE MEMBER
I wouldn't run any boat without a sea strainer, protects the impeller, t-stat, coolers, circ pump + it's a visual check for water flow on startup.
Wobble is offline
Old 02-27-2006 | 10:32 AM
Smitty's Avatar
Call Teague Marine. they have some on sale right now.
Smitty is offline
Old 02-27-2006 | 08:45 PM
I would recomend strainers for both the 525's, and the 496's. I have a pair of 496's. Was having constant problems with the coolers plugging up. I went with Hardin Marine strainers, due to the ease of cleaning. Mine are difficult to reach, and having the screw in lid from the top was the best option for me.
http://www.hardin-marine.com/product...-strainers.htm
Island Hopper is offline
Old 02-27-2006 | 09:42 PM
Too Old's Avatar
Look for ease of mounting and easy clean out.
Too Old is offline
Old 02-27-2006 | 09:54 PM
betitbig's Avatar
Fred, I like the one on the left. Is that your brand or?
I also just saw your post on the KPM ones.
Purple real nice...
betitbig is offline
Old 02-27-2006 | 09:57 PM
betitbig's Avatar
I wouldn't buy anything a Teague Marine even though I'm in California...
Isn't that like moving over to the dark side?
betitbig is offline
Old 02-27-2006 | 10:33 PM
Too Old's Avatar
Purple real nice...
The top photo is the Stainless Marine Super Strainer.
The bottom two are ther new CMI strainers.
Too Old is offline
