Has anyone used these Summit heads? >
Old 03-03-2006 | 02:20 PM
Default Has anyone used these Summit heads?
I would really like to see the flow numbers
Any idea who made the heads?
http://store.summitracing.com/defaul...h.asp&x=18&y=8
1BIGJIM is offline
Old 03-04-2006 | 08:14 AM
duunoit's Avatar
Default Re: Has anyone used these Summit heads?
That would be interesting to know....
duunoit is offline
Old 03-04-2006 | 10:00 AM
PatriYacht's Avatar
They look like Dart Iron Eagles. Good choice for running in salt water.
PatriYacht is offline
Old 03-04-2006 | 10:25 AM
ratman's Avatar
call summit and ask, i think they own trick flow which makes a lot of the summit branded speed eqiupment
ratman is offline
Old 03-04-2006 | 10:27 AM
ratman's Avatar
id go with alum, all the good alum heads are coated to prevent corrosion, and you're less likely to detonate an alum head eng.
ratman is offline
Old 03-04-2006 | 11:39 AM
I don't run in salt so corrosion is not a problem. Just the exact runner size and valves I am looking for. Only if they had the flow numbers. I know nothing is free, just wish they had more info, or someone who has had experience with them.
1BIGJIM is offline
Old 03-04-2006 | 12:54 PM
Wink Re: Has anyone used these Summit heads?
These iron heads seem to have pretty good specs. and the 308cc intake runner will be good for midrange torque and a BBC motor up to 540 inches with mild compression of lets say 9.0 to one. I think if your going to be running fresh water, I would spend a bit more and step up to a decent set of aluminum heads with similar specs that will let you run 10.0 to 1 with the same fuel octane. that extra point of compression is good for at least 25 more HP and a little more torque, not to forget you just thre another 100 lbs off the boat." Eventually they stopped using swords made of iron and stepped up to steel"!
Ray @ Raylar
Raylar is offline
Old 03-04-2006 | 01:40 PM
I would want to know who made the valve springs and what valves are in it. I really doubt the valves are made of a material suitable for extended marine use.
Griff is offline
Old 03-04-2006 | 01:45 PM
Big Block Billy's Avatar
Thumbs up Re: Has anyone used these Summit heads?
Yes, I used the 308 CC on my 540.
Using 345cc on a pair of 588's for a friend. Any bigger that 540 use 345cc. Dart heads are awesome ! They are really the way to go. Anyone need stock chevy heads ? I'd like to flush out my tremendous inventory. BBB
Big Block Billy is offline
Old 03-04-2006 | 01:47 PM
Post Re: Has anyone used these Summit heads?
Also using all Rev brand parts. Inconnel 11/32 valves, Titanium retainers etc... BBB
