Polishing my new lowers >
Old 03-05-2006 | 11:01 AM
PatriYacht's Avatar
Default Polishing my new lowers
Since it's still cold here, and I can't do any work outside, I decided to polish the lowers on my new ( to me ) Imco lowers. I used 6 sheets of 220 wet sandpaper, 2 sheets of 320, 2 sheets of 400. Sanding took about 5 hours to get all imperfections out of one drive . For polishing I used white polishing compound that can be found at any auto parts store and a polishing wheel mounted on an electrick drill. For a brighter finish I may try some Semichrome polish on it. It came out pretty well. Unfortunately it looks like some casting imperfections were repaired at the foundry with welding rod. They show up as those round spots. In sunlight they aren't as noticable.Hers a pic after one was finished.
PatriYacht is offline
Old 03-05-2006 | 11:36 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Polishing my new lowers
Looks good. How many drills did you go thru?
I have an electric 3/4hp motor that a made an extension to slip over the shaft to extend it out and mounted a 10 or 12" wheel to. Just like a regular buffing motor. Makes it so much easier. Are you going to clear coat them? Could even silver paint them to cover the spots.
US1 Fountain is offline
Old 03-05-2006 | 02:43 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
they look good
In conversation with a few people I have heard that a slightly rough lower is slightly faster Have you done any research on this I no this topic has had some differing opinions
klaw is offline
Old 03-05-2006 | 02:59 PM
PatriYacht's Avatar
I haven't heard that unpolished is faster on the lowers. Maybe on the props. I doubt if it'll be noticable anyway. The drill's holding up ok but my arms and hands are sore. I'm not going to clear them, just use mag wheel cleaner on them every time I wash the boat.
Old 03-05-2006 | 06:04 PM
That looks great.Did you wet sand the whole time and did you use a sanding block.I am going to takle that on my Promax 300 lowers.
fishead is offline
Old 03-05-2006 | 06:15 PM
Payton's Avatar
Charter Member #927
Ian, that looks great. Nice work. You might try some sealing polish for alum to help hold the shine between touch ups. I think Mothers or Wizard makes some very good ones.
Payton is offline
Old 03-05-2006 | 09:01 PM
ratman's Avatar
the one you finished looks awesome compared to the before pic
ratman is offline
Old 03-05-2006 | 09:12 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Wonderful! I'll bring mine right over!
Sydwayz is offline
Old 03-05-2006 | 10:14 PM
Vinny P's Avatar
I hate the winter!!
My Imco lower has the same casting marks. I dont know why they are there, but it appears they are plugs that get welded in after the casting process. I polish mine once in a while but it doesnt hold up. I run only in salt water, dont know if thats why, but after a short while, it looks like I didnt do anything to it.
Vinny P is offline
Old 03-06-2006 | 09:15 AM
Ms PatriYacht's Avatar
8 hours of polishing, yet I can't get him to unload the dishwasher
I just checked for myself in the basement, they look even better in person, thanks for working hard to save us money
Ms PatriYacht is offline
