No Pwr When Cold Pwr Stroke 6.0 2005 >
Old 03-07-2006 | 09:13 AM
Angry No Pwr When Cold Pwr Stroke 6.0 2005
For The Ford Guys I Have A 2005 F450 6.0 Pwr Stroke Diesel. Question, When The Truck Is Cold It Has No Pwr And The Turbo Boost Gauge Jumps To 40psi? When It Warms Up It Seems To Run Fine And Boost Level Seems To Be Normal. Any Help Would Be Greatly Appreciated. This Truck Is Totally Stock No Chips Etc.... THIS IS WHEN THE ENGINE IS COLD. THE TRUCK IS STORED INSIDE 45-50deg.NOT PLUGGED IN. DON'T KNOW DURING THE WARMER MONTHS IT JUST STARTED TO DO THIS.
paxtonsc is offline
Old 03-07-2006 | 10:54 AM
Sean H's Avatar
A to Z
Default Re: No Pwr When Cold Pwr Stroke 6.0 2005
when the engine is cold or when its cold outside?
i always plug my truck in or park inside and have no problems, i have an 05 too...
Sean H is offline
Old 03-07-2006 | 12:23 PM
Formulabill's Avatar
Dura Max
Formulabill is offline
Old 03-07-2006 | 12:49 PM
From: A tree somewhere in the woods in Clarcona Fl.
Bad Wastegate?
Slick02 is offline
Old 03-07-2006 | 05:12 PM
Dealer Said Pcm Re-program. Checked For Codes No Codes Listed. It Will Be There Tomorrow (dealer). Truck Has 11000 Miles Thanks For Your Help.
paxtonsc is offline
Old 03-07-2006 | 05:49 PM
Sean H's Avatar
A to Z
Originally Posted by Troutly
It sounds like the variable vanes on the turbo are sticking, causing it to overboost. You need to find out why this is. A trip to the dealership is in order so they can have it overnight. That when they can start it when cold to try and duplicate the problem. There also might be codes stored already that will help them out, even if the is no Check Engine light on.
overboosting? mine doesn't run good till around at least 35...
Sean H is offline
Old 03-08-2006 | 12:18 AM
speedygonzalez's Avatar
I believe that it has a sensor if your motor is not up to normal operation temp it by passes. I have a similar sitution so Ijust turn it on a few minutes before I leave the house.
speedygonzalez is offline
Old 03-08-2006 | 08:36 AM
buck183's Avatar
Remote start. Problem solved.
Buck
buck183 is offline
Old 03-08-2006 | 12:27 PM
Just Got The Truck Back From The Dealer. Pcm Re-programmed Runs Like A Top.
paxtonsc is offline
cooltoys61
0
04-09-2004 08:39 AM
rick32
10-11-2002 10:39 PM
Dave F
06-11-2002 10:17 AM
