Holly 800cfm carb. >
Holly 800cfm carb.
Holly 800cfm carb.
Old 03-07-2006 | 06:11 PM
Default Holly 800cfm carb.
Has anyone used the 800cfm marine holly on a 330hp 454 with any luck? I know you guys told me to use the 750 cfm but teauge swears by th 800 and they do this everyday.
mtocrs1 is offline
Old 03-07-2006 | 06:30 PM
formula31's Avatar
Default Re: Holly 800cfm carb.
Can be done but not necessary. Especially on a stock engine or any 454 turning less than 5400. Ive tried and still prefer the 750. Better starts, acceleration and fuel mileage. There are those using them succesfully. Better for a 502 IMHO.
formula31 is offline
Old 03-07-2006 | 07:46 PM
For that type of Power A 750 is going to be a much better choice.
RumRunner is offline
Old 03-07-2006 | 07:50 PM
Ditto on what they said.
Griff is offline
Old 03-07-2006 | 07:56 PM
98itrwhite's Avatar
i am going to use one this year, not by choice it came with the heads and intake as a pakage deal. i would rather have the 750 but i will give it a try.
98itrwhite is offline
axapowell's Avatar
Where To
454 (ci) x 5400 (max RPM) = 2451600 / 3456 = 709.375 cfm
Just my .02
Dave
axapowell is offline
Old 03-07-2006 | 09:17 PM
formula31's Avatar
Remind me guys, which is it? I think you can get away with a larger carb on a dual plane intake, right?
Old 03-08-2006 | 07:22 AM
A dual plane intake can help crutch using a carburetor that is too big, but remember that carburetors work based on air velocity. If a carburetor is too large for the application there won't be enough air velocity, and it will run lean at WOT. If Boob sold you the carb, he may already have some pistons put aside for you. You're going to be better off with the 750 carburetor, regardless you're not going to get the 5 MPH gain you want without going into the engine.
Old 03-08-2006 | 09:08 AM
formula31's Avatar
Thats very true, when I tried the 800, I had to jet the heck out of it.
boatme
07-03-2008 11:01 AM
tmthunder
5
10-25-2004 07:36 PM
blue thunder
2
01-17-2004 11:13 AM
timucin
08-03-2003 08:41 PM
MIKE H
19
06-02-2003 12:02 AM
