Go Back  Offshoreonly.com > Owners Forum > Powerplay
80's vintage - 18' powerplay >
Old 03-08-2006 | 08:45 AM
Default 80's vintage - 18' powerplay
Does anyone have any info on an 18' powerplay that was built in the( 80's ?) I saw one once, that had 2 buckets up front, a bench seat in the back, and a sunpad on the engine hatch. Powered by a 260 Merc.-alpha drive, with thru-hull exhuast.
Nice little lake boat! I have never seen another one.
wrenchman is offline
Old 03-08-2006 | 09:04 AM
Default Re: 80's vintage - 18' powerplay
I believe thats a powerquest boat.
cowisl is offline
Old 03-08-2006 | 09:15 AM
Stormrider's Avatar
JC Performance Engines
They did make a boat like that.
Someone on the board has one for sale.
Stormrider is offline
Old 03-08-2006 | 09:39 AM
Indy's Avatar
Member #154
It is what's now known as Powerquest, and Travis has one for sale. Send him a PM or read here...
http://www.offshoreonly.com/forums/s...d.php?t=122420
Indy is offline
Old 03-08-2006 | 10:06 AM
Stormrider's Avatar
DUH... I stand corrected.
That is the one I was thinking of.
Old 03-08-2006 | 03:24 PM
dyno's Avatar
Charter Member #655
but when they were built it was a" Power Play" out of Holland Michigan great boats hold there value like a vette, wish I had one. The original hull was called a Baron and the owner is on the board "Baron Marine" Todd can tell you all you need to know and then some.Search Baron Marine and I'll bet you can find all sorts of stuff right here on OSO.
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 03-12-2006 | 05:54 AM
I also have one for sale . But not as nice as Travis's.
It is a great Lake/Bay boat. Wish it was 3 ft bigger but i need
something a little bigger . Long Island Sound gets a little ruff.
2 Buckets in front bench in rear. deep v no pad under hull.
Currently listed on Scream and Fly in under 20 ft
Daddio
Ps, it is a powerquest But says Powerplay on the sides
Company split ?
Daddio is offline
Old 03-12-2006 | 07:15 AM
Indy's Avatar
Member #154
Daddio - where do you boat on LIS? There are a few of us out of Norwalk. I could imagine that it's a bit bumpy out there for a boat that size especially if you're getting on the throttle
Indy is offline
Old 03-12-2006 | 09:11 AM
birdog's Avatar
Company split ?
No...They started as Powerplay. When the real PP found out they made them change. I dont think they even knew PP existed when they did that. PP was not well known up here before The internet
birdog is offline
Old 03-13-2006 | 04:03 AM
I am in Niantic CT but go over to Orient Point , Greenport ,
Montauk and sometimes to Watch Hill RI . Like I said
"If it was 3 ft longer" Id keep it .
Daddio
Daddio is offline
