425-450HP BBC for less than $5000? >
Old 03-12-2006 | 05:48 PM
Default 425-450HP BBC for less than $5000?
I have a dead 454 MkIV that I will be replacing in a Cig 20 with a Merctrans and TRS drive. The Edlebrock Performer 2.0 intake and 750cfm carb are about all that I can save. Long block is scrap. I've been wading through forum searchs and found loads of info, but not exactly what I need. Finally my question: can I buy/build a bulletproof 425-450 HP BBC for less than $5,000? Something that will run 5000RPM's for an hour if we want. Thanks for any help/info.
Nicotine Fit is offline
Old 03-12-2006 | 05:50 PM
375stinger's Avatar
Default Re: 425-450HP BBC for less than $5000?
did you run 5000 rpms for an hour straight before? what is "dead" about your engine?
375stinger is offline
Old 03-12-2006 | 06:14 PM
The "hour straight" was just in theory, sometimes we do run WOT for maybe 10 minutes after engine is warm.
I pulled the intake and heads off and found #6 piston had disintegrated, looks like the free connecting rod then broke the cam and did a number on the block. I haven't actually checked the crank, but I would never trust it.
Old 03-12-2006 | 08:17 PM
i would think you could buy 454 long blocks all day for 5k from about 50 different sources. whats in them will depend on who you buy from but i would think no problem...
stevesxm is offline
Old 03-12-2006 | 08:37 PM
I need to buy almost everything: block, rotating assembly, probably heads and the exhaust manifolds are original and have cracks, so those too.
Old 03-12-2006 | 09:03 PM
woody1's Avatar
I could piece together a Big Ford that will make 500hp all day long with iron heads for less than 5k, I sure as hope you can do a chevy for less
woody1 is offline
Old 03-12-2006 | 09:30 PM
You want exhaust included too for under 5k???????
Simple answer then would be, NO you can't.
Griff is offline
Old 03-12-2006 | 09:51 PM
onesickpantera's Avatar
But you can get a 450 hp FULL DRESS Volvo Marine motor for $7k!
onesickpantera is offline
Old 03-12-2006 | 10:34 PM
I know, I must be dreaming.
Old 03-13-2006 | 09:25 AM
NicotineFit
We have been beat up by this place on 454 long block's. Lost out on 4-engines within the last 90 day's.
Long block $4095 !
try www.perfprotech.com
Richard @
RCD Racing Engines
Little Rock, SCarolina
AA/FuelCoupe is offline
