gimble play?
My bravo drive is off and I fount that my gimble has slop side to side and up and down, almost like its mising thrust washers?? I get around 3/32" movement on both directions.....
Mine has the side to side play also. Bought the kit from jrmarine and took the ring off. It did not seem that bad to me, but there was enough wear to cause the slop. Sent the ring in Monday for repair to jrmarine and should have it back by this monday.
Ron Bender has been real helpful with my problem.
The slop is in the distance between the the bell housing & the gimble ring. Its not side to side from slop at the top pin. Picture out-drive & off holding bell housing at trim senders and moving side to side almost 1/8" along with seeing gaps between surfaces at hinge screws. Up and down is the same???
I see. Only thing I seen when disassembling it all was washers on each side of the bell housing. Not too thick and also not made of metal which may have worn away.
Also the hing pin bushings could be worn. Mine were a bit worn, but did not have any real slop from it.
If you grab the steering pin and move it side to side does the gimbal move from side to side or just a little slop? I'm going through the same thing now.
Up and down play of the ring is controled by the nut on the upper swivel pin. There should be .05" (I think, anyone got that spec?) clearance (slop) there. I use a dime to set it. Sideways slop of the ring should be 0. If it's there, you've got a loose pin in the ring or gimbal pin bearing worn. Clearance inside the ring, at the hinge pins, should be nearly 0. Your washers may be worn or gimbal ring damaged if thats the case.
Gary
Gary
