5 blade vs. 4 blade prop >
Old 03-19-2006 | 12:02 AM
Rebel_Heart's Avatar
Default 5 blade vs. 4 blade prop
How do you know when your application would benefit from a 5 blade prop? Is there some general rule or should you always just test both to be sure?
Rebel_Heart is offline
Old 03-19-2006 | 08:55 AM
Harper220's Avatar
Default Re: 5 blade vs. 4 blade prop
If you're having trouble getting on plane with a 4 blade a 5 blade can help, also if you have high prop slip at mid-range speeds again a 5 blade can benefit by reducing the slip resulting in more speed. Typically a 5 blade will not be as fast on top end, but will make up for it in all other areas. I went to 5 blades and I'm very happy with their performance.
Harper220 is offline
Old 03-19-2006 | 10:13 AM
TeamSaris's Avatar
Driver-441
Racer
I heard that 5 blades arent qiute as fast but they slice water a lot smoother.
TeamSaris is offline
Old 03-19-2006 | 10:27 AM
Beak Boater's Avatar
Charter Member # 545
We tried them on our 35 Fountain, we saw the same as what Harper discribed. Got on plane easier, cruised 3-5 mph faster in the mid range, 3300-3800 rpm, but was 4 mph slower on the top end than the 4 blade. That was running Hydromotives P5 and 4 blade. Hydromotive said they can get the 5 blade as fast as a 4 blade but it would require labbing, deffusier ring adjustments ect. Have heard both that they are harder on drives and easier. Easier because they have less vibration because more blades in the water at once, and harder because they dont slip as much. Currently have 5 blade Maximus on our 38 Fountain with shorties, will start experimenting with props when the weather warms up a little. The biggest gains are in high slip applications, like cats with very high X's and when the blades are sufacing. If your props are not surfacing, its hard to beat a 4 Blade.
Beak Boater is offline
Old 03-19-2006 | 11:12 AM
Thanks for the information. The reason I am asking about 5 blades is because I am considering 2"shorties. Even with the x-dimension higher do you think that 4 blades will have the better top speed. Do the 5 blades make up for the slippage?
Old 03-19-2006 | 11:30 AM
Comanche3Six's Avatar
Good info...thanks
Comanche3Six is offline
Old 03-19-2006 | 11:47 AM
Harper220's Avatar
I just added 2" IMCO shorties to my 28 Daytona and will have to wait till it gets nice enough to try the p5x's to see what the shorties will do. Hopefully I'll pick up my rpm's on top enough to step up a pitch. On the down side, I hope I haven't gone up too high or I'll have to add a 1" spacer. I guess it's just a matter of experimenting to see what works best.
Old 03-19-2006 | 03:03 PM
The 5 blades are slower at top end but better at mid range and getting on plane as stated earlier,they raise the drives with the 5 blades to acheive similar top end as the 4 and still get on plane and have a better mid range.The 4 blade would probably be better at top end with a higher drive but you would't be able to get on plane
JMPH is offline
Old 03-19-2006 | 04:46 PM
Sounds as though I'll stick with the 4 blade for top end. I, too hope that I will pick up speed by going higher because I know I will have more slip. Guess there is no way to find out except by experimenting. Just trying to save some $ on the shorties if there is not speed to be gained.
Old 03-20-2006 | 11:24 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: 5 blade vs. 4 blade prop
You guys keep this up and you won't need us on the board anymore. All very good information.
Testing is the only to ultimately know what will work the best for your set up. Maintaining the best efficiency with low drag is the key!
[email protected]
bbladesprops is offline
