Billet Trim/Tab pump tank/mount
Old 03-22-2006 | 05:57 PM
teaguecustommarine's Avatar
Offshoreonly Advertiser
Default Billet Trim/Tab pump tank/mount
NO more cracked tanks
NO more puddles of oil
NO more stock black floor mount merc bracket
unlike other aftermarket billet trim tanks this one
has a sight glass so you can see the level of the
fluid and no worries of not enough fluid or overfilling
the tank. The tank can be ordered with two brackets,
a floor mount or transom mount. If you are going to use
the tank as a floor mount you just screw it right to the floor
and no need for that stock bracket.
the tanks and solenoid mounts are all made of 6061 T-6
BILLET ALUMINUM, the motor support bracket is made
of STAINLESS STEEL and comes with the transom
solenoid mount. the tank sells for $ 229.oo no additional
charge for the coolness it will add to the boat but you
will need to purchase the back bracket
give me a call or e-mail me if you have any questions
thanks for checking out my post
Adrian
Attached Thumbnails Billet Trim/Tab pump tank/mount-tcm-billet-trim-side.jpg   Billet Trim/Tab pump tank/mount-tcm-billet-trim-top.jpg   Billet Trim/Tab pump tank/mount-billet-trim-clean.jpg
teaguecustommarine is offline
Old 03-29-2006 | 07:27 PM
Default Re: Billet Trim/Tab pump tank/mount
OHH and if you like the stock black bracket, it will fit .
So now there is only one choice when it comes to
trim pump tanks. Sight glass. E Z fill and mounts anywhere
Attached Thumbnails Billet Trim/Tab pump tank/mount-trim-tank-stock-brkt.jpg   Billet Trim/Tab pump tank/mount-trim-tank-stock-bracket-2.jpg
Old 04-19-2006 | 07:37 PM
OK i have polished in stock
Transom Mount Brackets and
Floor Mount brackets.
the transom mount brackets come
with all the mounting hardware, bushings,
and motor support bracket.
you can adapt your floor mounts to transom
with no problems or simply just change over
your stock to the billet.
the floor mount brackets also come with the
bushings and bolts for back of tanks and pump.
OHH and both come with the socket head bolts
to mount all the solenoids to the bracket.
nothing else needed just remount using the hardware
kit (included) and GO GO GO
Blue, Red, Pewter, Purple and Black are on the way from the anodizer
Attached Thumbnails Billet Trim/Tab pump tank/mount-trim-pump-tank-tm.jpg
Old 07-11-2006 | 07:46 PM
will the transom bracket mount to a regular trim pump? If so how much for the bracket
ingveys is offline
Old 07-28-2006 | 11:54 AM
the transom bracket does mount to the stock pump and motor.
it comes with all the bushing and hardware needed to mount everything and it also comes with a motor suport (polished stainless steel) the sale price of the bracket (transom mount)
is $69.97 (make sure that your pump has the four small tabs so you can bolt it down to the tank)
Old 10-17-2007 | 12:43 PM
ORDER YOURS TODAY AND GET THE TURBOSONIC PERFORMANCE CAP your choice of color AT NO ADDITIONAL COST
Donzi John
Swap Shop
6
05-27-2010 01:10 PM
Sick Stinger
Wanted
7
09-27-2008 11:04 AM
Rexx
5
09-28-2007 11:29 AM
awsomethunder
2
05-04-2006 11:58 AM
tpmarine.com
New Products and Member Discounts
7
04-21-2006 12:30 AM
