what is the rpm range for a 731 cam? >
Old 03-27-2006 | 07:31 AM
BajaRunner's Avatar
Default what is the rpm range for a 731 cam?
Ive got a 731 in a carb'd hp500. whats the dropoff point? Im hitting 5600 and wondering if im hitting a wall. I was about to put on a taller set of props when i think a head gasket went. just curious where this thing is dropping off in power.
BajaRunner is offline
Old 03-27-2006 | 05:49 PM
Strip Poker 388's Avatar
Rob
Default Re: what is the rpm range for a 731 cam?
I would think your close
Strip Poker 388 is offline
Old 03-28-2006 | 10:13 AM
PatriYacht's Avatar
You might be past it already. Try a 741 if you like to rev that high.
PatriYacht is offline
Old 03-28-2006 | 10:25 AM
BajaRunner's Avatar
I dont like to rev that high. I would have went with the 741 if i didnt have the gils.
Im just wondering if im running out of power and can twist a bigger prop. i guess only one way to find out
Old 03-28-2006 | 12:05 PM
PatriYacht's Avatar
Good idea on the bigger prop.
Old 03-28-2006 | 12:38 PM
pachangalpina's Avatar
My motor was starting to falling off on the dyno above 5500 with that cam.
pachangalpina is offline
Old 03-28-2006 | 12:57 PM
Rob
On the 741 cam
Mine has mild ported heads and is blown ,it pulled to 6200 ok.
Maybe Mike280 will chime in ,he and his bro has a lot of experance with these 2 cams!!
Rob
Old 03-28-2006 | 01:13 PM
Lifters may be giving up. . .
cstraub is offline
Old 03-28-2006 | 03:53 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
My HP motor would spin 5800 with the 741 no problem. Not that I ran it that hard all the time. Also was running the merc/Gil exhaust with silent choice.
US1 Fountain is offline
barry d.
4
06-18-2008 06:46 AM
batty
5
01-13-2004 09:54 AM
Scott
7
02-25-2003 08:59 PM
mk3jlp
2
10-07-2002 08:04 AM
