speedmaster hinge pins >
Old 03-28-2006 | 05:53 AM
Default speedmaster hinge pins
Can you greese #4 speedmaster hinge pins with out disassembly? Mine are popping when I raise and lower my drives . I think this is contributing to my drives being lazy also .
boatman747 is offline
Old 03-28-2006 | 06:06 AM
Default Re: speedmaster hinge pins
I Rebuilt Mine No Grease Fitting Their. If The Pin Is Popping The Helmet Is Probably Worn Also.
z.zuperboat is offline
Old 03-28-2006 | 06:43 AM
whats the rebuild , remove clean and reinstall?
Old 03-28-2006 | 10:26 AM
That All Depends On How Worn It Is. Mine Had To Be Heated With A Torch To Get Apart. The Helmet Pin Hole Where Oblong. Sent Then Out To Be Oversized And Bushings Installed. Its Not Easy To Get Apart, The Hindge Pins Have Little Pins That Go In With The Little Set Screws That Hold Them In .
Old 03-28-2006 | 06:46 PM
I removed the allen bolts and filled with liquid wrench . One drive is free , the other side will require removing the pin . Tomorrows task .I must create a slide hammer from all thread . All I need is a little movement and I think all will be good .
US1 Fountain
13
04-08-2004 08:28 AM
jhnrckr
3
03-17-2004 06:21 PM
CAP071
4
05-21-2003 07:49 AM
28SS
3
02-04-2003 08:35 AM
THRILLSEEKER
18
09-10-2002 01:13 PM
