Bravo 1 or  Hydromotor Need Some Help!! >
Old 03-28-2006 | 10:57 AM
30 outlaw 2005's Avatar
Default Bravo 1 or Hydromotor Need Some Help!!
Running a 30 Outlaw with 496(375hp) Bravo 1's turning 5200 WOT at 72 GPS 3/4 tank of gas with 3 people. Runs good but hitting rev limiter. Should I go with 28 Pitch Bravo and have them labbed or go with a set a labbed Hydromotor Intimidator IV? Any and all info would be great Thanks...
30 outlaw 2005 is offline
Old 03-28-2006 | 11:49 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Bravo 1 or Hydromotor Need Some Help!!
I'm confident you will prefer the Bravo 1's to the Hydro Q4 on your hull.
What pitch are you running now?
I'm a little surprised you can turn 5200 with your 496's. You may want to check your tachs. The rev limiter is at 4950.
Rotation can greatly affect the performance of you hull too.
[email protected]
bbladesprops is offline
Old 03-28-2006 | 01:04 PM
Default Re: Bravo 1 or Hydromotor Need Some Help!!
Running 26 pitch now non labbed tach reads 5200 when the rev limiter stops it. Props spinning outward. will have to check them but as of now that is what they are reading
Old 03-28-2006 | 01:07 PM
ZBODaytona's Avatar
Isn't the rev limiter of the 496 5150????
ZBODaytona is offline
Old 03-28-2006 | 01:09 PM
That is what i thought also.
Old 03-28-2006 | 02:43 PM
Dave1972's Avatar
Based on Merc's website the 496 WOT RPM should be 4400-4800 I'm not sure about the rev limit though I'm sure someone will pipe in here and give us the facts
Specifications
SmartCraft: Yes
HP: 375
kW: 280
Displacement Liter/CID: 8.1/496
Cylinder/Configuration: V-8
Bore & Stroke (in): 4.25 x 4.38
Bore & Stroke (mm): 108 x 111
Compression Ratio: 9.1:1
Fuel System: MPI
Full Throttle RPM Range: 4400-4800
Ignition System: PCM 555 Distributorless
Alternator Amp: 65
Alternator Watt: 917
Drive/Gear Ratios (primary/optional/high altitude): Bravo One: 1.5/1.36/1.65:1
Dave1972 is offline
Old 03-28-2006 | 06:54 PM
The HO version is 5150.
Mercruiser usually goeas 150 rpm above rcomended WOT.
Mercury Racing will usually go 200 over.
[email protected]
Old 03-28-2006 | 07:00 PM
Do you think I would be better off with staying with the Bravo 4 blades or going to the Hydro Q4. What do you think I would get out of the Hydro Q4's?
Old 03-29-2006 | 09:05 AM
My advice would be to stay with Bravo 1 series propellers. I don't believe you will have any advantage with the Hydros.
[email protected]
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
