Heavy Oxidation
Old 03-28-2006 | 07:51 PM
Default Heavy Oxidation
Is it possible a time comes when you can not restore the gel coat. I have tried the past couple of years with limited success. I have read several threads and never seen this addressed.
JIM
1BIGJIM is offline
Old 03-28-2006 | 09:21 PM
glassdave's Avatar
Neno the mind boggler
Default Re: Heavy Oxidation
yes there is a point where the gloss can no longer be restored. some gels get so porous with age that they can only be buffed with limited success. it depends on how the boat is kept through its life and the quality of the products used when it was made. no real exact science to it though, i had a dark gray Scorpion that would only hold a gloss for a few days, it was much easier to just paint it than try an keep the gloss on the gelcaot.
08 OPA High Points Champion
glassdave is offline
Old 03-29-2006 | 07:09 AM
JIM
When you reach the point where buffing no longer works you can often bring the finish back with wet sanding. Take a look at the other thread going here now. TROUBLE WITH FINESSE IT II
RaggedEdge is offline
Old 03-30-2006 | 02:59 PM
I thought mine had reached that point. Try SeaPower cleaner wax, boaters world has it for like $7.99, it may suprize you.
spk1 is offline
Old 04-04-2006 | 04:23 PM
I was Guessing when I said "Cleaner Wax" it may be the same stuff, but the bottle I used was "COLOR RESTORER" make sure you ask for that. I am going to try the cleaner wax out to see if it is the same stuff.
spk1 is offline
Donzi Corleone
01-10-2008 07:26 AM
fastted
Detailing, Painting, & Fiberglass
5
07-22-2007 07:46 AM
spk1
3
04-15-2006 09:30 PM
sre
08-03-2004 09:52 PM
LLcoolBaja
6
05-30-2002 10:21 PM
