502 w/ 25 pitch prop, What RPM? >
Old 03-30-2006 | 07:56 AM
wieland77's Avatar
Default 502 w/ 25 pitch prop, What RPM?
I bought a 1987 28' Saber a couple months ago and I was able to run it for the first time this past Sunday. I dont know anything about what was done to the motor accept it was recently gone through by More Power in Grand Rapids, MI. They replaced the rings and a piston, put in new bearings and polished the crank and cam. It has IMCO manifolds and a hi-rise Dart intake with a 950hp double pump Holly carb. I do not know the HP rating for the engine.
It has a 25 pitch 3 blade mirage prop on it and when running wide open I was running around 4700-4800 rpm and on;y getting 57 - 58 mph depending how the drive was trimmed.
Is this prop a little too much for the engine. It seems like I should be in the 5100 - 5300 rpm range. I dont know a whole hell of a lot about props and what would be the best match for what I have.
Am I where I should be or should I go with a different prop, and if so what one? Any info would be appreciated.
Attached Thumbnails 502 w/ 25 pitch prop, What RPM?-4.jpg
wieland77 is offline
Old 03-30-2006 | 08:17 AM
Tantrum's Avatar
Default Re: 502 w/ 25 pitch prop, What RPM?
Did you do a leak down test on the motor? It sounds like you should be getting more from that set-up than you are.
The way that it is running now i would say that yes, you are over-propped. If there is no rev limiter to check I would think you want to be at 5100rpms.
There is alot of guessing here...you best bet would be to get the motor on a dyno and see what kind and where it makes its HP.
Tantrum is offline
Old 03-30-2006 | 08:28 AM
Pantera1's Avatar
Try a 23 four blade.
Pantera1 is offline
Old 03-30-2006 | 08:37 AM
wieland77's Avatar
A buddy of mine has a 4 blade 22 pitch that I can try out and see what it does, I also have a 23 ptch 3 blade mirage off my 454 330hp motor that I could try also.
Old 03-30-2006 | 08:44 AM
Airpacker's Avatar
is it a 1.50:1 or 1.36:1 drive?
Airpacker is offline
Old 03-30-2006 | 08:54 AM
Wobble's Avatar
SORE MEMBER
The four blade 22 bravo-1 should be a good starting point with a 1.5-1 outdrive. I would have thought that your setup would easily turn a 24 b-1 4 blade.
I run a 28' with a 509, can turn the 24 pitch b-1 prop to 5800 rpm. Probably could turn a 26, but don't want to torque the outdrive too much.
Wobble is offline
Old 03-30-2006 | 09:10 AM
wieland77's Avatar
My dive is a 1.5 gear
wieland77
14
04-03-2006 04:33 PM
zimm17
Prop Talk
5
12-14-2005 08:00 PM
plumbers crack
05-31-2004 11:57 AM
Water Pistol
1
04-27-2004 07:08 AM
puder
3
08-24-2003 10:57 PM
