do aftemarket companies make gear sets for merc drives? >
Old 03-30-2006 | 09:22 PM
ratman's Avatar
Default do aftemarket companies make gear sets for merc drives?
i priced a set of upper gears for a ssm#3a and mercs retail is like 2700 bucks.... wtf i can get a ring and pinion set for and muscle car for 2 hundred and change, and theres a lot more metal and mchine work there. are there compnies that will make gear sets for drives other than merc? rm
ratman is offline
Old 03-31-2006 | 11:45 AM
Default Re: do aftemarket companies make gear sets for merc drives?
If There's Not Someone Making Gear Sets, There Sure Should Be.....the Profit Margin Has To Be Huge If They Already Have The Equipment! Not Just Gear Sets, But All Kinds Of Internals. Trs Parts Are Starting To Dry Up Especially.
SHAWNA is offline
Old 03-31-2006 | 11:53 AM
The company I'm with has manufactuering process that is based on the machines that power the flow water jet cutting stuff, same machine used on American Chopper and Hot Rod to make rims and cut other metal parts out with....
It would not take much to get the rest of the equipment needed to cut with and I'm seriously thinking about it, as a sideline.......
Zudnic is offline
Old 03-31-2006 | 03:24 PM
Only two minor problems: quantity and metallurgy. Solve both of them and you've got it made...
burtandnancy is offline
Old 03-31-2006 | 03:26 PM
ratman's Avatar
there are an azz load of diffderent companies making ring a pinion sets, that will handle 1000+ ponies how hard could it be?
ratman is offline
Old 03-31-2006 | 03:36 PM
Panther's Avatar
Frank's Marine Service
From what I understand it's not the cost of making the gears, it's the cost of making the pieces that forge the gear.
If I remember correctly, IMCO said it would cost around $150K to have it made, that's why they don't do it.
Panther is offline
Old 04-01-2006 | 05:01 AM
CAP071's Avatar
quantity and metallurgy You got it
CAP071 is offline
Old 04-01-2006 | 10:55 AM
The flow water jet you just put your shape wanted in its computer and put the block of material on the cutting table and it bangs out whatever you need.
http://www.flowcorp.com/waterjet-resources.cfm?id=460
http://www.flowcorp.com/waterjet-app...ons.cfm?id=108
Zudnic is offline
Old 04-01-2006 | 12:02 PM
The Menace's Avatar
Call Steve @ 800 932 9120 x210
He makes a lot of different marine parts for a lot of different manufacturer's. I know he makes spline shafts. If not, he may be able to put you on the right track.
The Menace is offline
Old 04-01-2006 | 12:27 PM
Comanche3Six's Avatar
I am sure a company like Richmond gear made those gears for Merc. .
Comanche3Six is offline
