Triples-my buddies warned me! >
Old 03-30-2006 | 10:33 PM
carrboy's Avatar
Default Triples-my buddies warned me!
Just got my boat delivered(386 sonic w/triple 500's),one of the keys isn't powering up the gauges for that motor.The motor will start but no movement from any of the gauges off that key.The needles don't even flicker when you turn the key on(you know how at least the tach will flicker when you turn the key to on-nothing).No blown fuses, no loose wires...any thoughts???Boat was fine and after sitting this is happening,thanks for any input,Mike
carrboy is offline
Old 03-30-2006 | 11:00 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Triples-my buddies warned me!
Check the (purple?) 12v wire coming off that ignition switch that powers the gauges for that motor.
US1 Fountain is offline
Old 03-30-2006 | 11:05 PM
miamioffshore's Avatar
The good news is that whatever it is, it's almost certainly 1 thing that has shorted all your gauges, so check everything at the base/stem of the power supply to the gauges, somethign is choking them all off.
miamioffshore is offline
Old 03-31-2006 | 07:08 AM
J-Bonz's Avatar
Voltmeter?
J-Bonz is offline
Old 03-31-2006 | 07:10 AM
Check the ignition kill switch circuit for that engine.
Edward R. Cozzi is offline
Old 03-31-2006 | 03:54 PM
Airpacker's Avatar
Prolly a bad contact in the ign switch. corroded while sitting. as mentioned, check for 12v power at the purple wire from the switch.
Airpacker is offline
Old 03-31-2006 | 06:17 PM
carrboy's Avatar
Just want to let all of you know I found it...was a bad tether switch!I made sure it was connected properly but the switch itself was bad... got to take it out today!!!78 degrees in cny on L.Ontario!Thanks,Mike
carrboy is offline
Old 04-01-2006 | 06:25 PM
Did you buy Blackjack?
MILD THUNDER is offline
Old 04-01-2006 | 06:36 PM
carrboy's Avatar
Nope,bought one w/500's
carrboy is offline
Old 04-01-2006 | 06:46 PM
I thought blackjack had 500's. Nice looking sonic you got there!!!!! Congrats
