imco extreme sc ? >
imco extreme sc ?
imco extreme sc ?
Old 03-31-2006 | 05:37 AM
Default imco extreme sc ?
Next year I plan to up grade power to approx 750+
currently at 600+ and have an xz drive. I ran across an imco sc for $5500.00 w/ 20 hrs in good shape. Question... Should I pick this up?
I need a seasoned vetrans advice.
tomcei is offline
Old 03-31-2006 | 08:41 AM
sterndrivespec's Avatar
Default Re: imco extreme sc ?
we sell a lot of imco drives.if it is a newer one that is a good price
sterndrivespec is offline
Old 03-31-2006 | 05:17 PM
NJSONIC's Avatar
Talk to Panther on this site about Imco's
NJSONIC is offline
Old 03-31-2006 | 05:27 PM
Banana Split's Avatar
Do your self a favor. Stay away from imco.. Been there done that
Banana Split is offline
Old 03-31-2006 | 06:29 PM
Too Old's Avatar
Too Old is offline
Old 03-31-2006 | 06:41 PM
Harper220's Avatar
I recently put a set of imco shortie 2" lowers on xz drives behind 496 ho's. I haven't ran them yet due to cold weather. Anything to be concerned about there?
Harper220 is offline
Old 03-31-2006 | 06:51 PM
KAAMA's Avatar
It would be helpful to know what kind of problems you have experienced with the IMCO's. Thanks
KAAMA is offline
Old 03-31-2006 | 08:49 PM
Vinny P's Avatar
I hate the winter!!
I dont see any particular problems with the SC. They suck just as much as a Bravo XR. The design of both are so similar, they both have the same weakness. After all, Imco uses Merc gears, nothing special there. Although I broke an Imco vertical shaft last year, I believe the shafts are a bit better. I had the old style vertical shaft with the oiling hole. Their new shaft design doesnt have that useless hole, so may be better.
Vinny P is offline
Old 03-31-2006 | 09:18 PM
Thanks guys. I found out that it is almost four years old and the lower is a two inch shorter version.(I ran the numbers thru imco) I think I'm goiung to pass. Man I love this site
tomcei is offline
Old 04-01-2006 | 09:01 AM
Harper220's Avatar
My father has over 200 hrs on 575 sci's running through Bravo xr's on his 36 Baja. Never experienced a problem with drives, so what seems to be the problem with summing them up as they "just suck"?
