Removal of exhaust gasket material >
Old 04-01-2006 | 05:51 PM
Kokopelli's Avatar
Default Removal of exhaust gasket material
Anyone have any suggestions of the best/easiest way to do this? Thanks!
Kokopelli is offline
Old 04-01-2006 | 06:45 PM
Default Re: Removal of exhaust gasket material
Sharp razor blade an patience. Don't use an air tool on it for danger of removing metal and causing a poor seal.
BadDog is offline
Old 04-01-2006 | 11:21 PM
Elbow grease, blood pressure in your head from hanging upside down for hours, brake clean and yes, a sharp razor blade. If you have steel heads, no problem, if aluminum, be careful as stated above... Get at it, it don't scrape itself!!!!
ghittner is offline
Old 04-01-2006 | 11:35 PM
BattleCry's Avatar
I use a circular green rubber attachment for my small grinder, It has a bunch of little green tits on it. It does not hurt the metal and is very quick and painless. I don't remember what they are called.
BattleCry is offline
Old 04-02-2006 | 08:09 AM
Payton's Avatar
Charter Member #927
I think 3M makes a gaket removal tool that works very well. It goes on the end of a drill and has replaceable pads. It's a stiff foam/emory surface. It works very well.
Payton is offline
Old 04-02-2006 | 08:17 AM
I have always used to razor blade method, be care not to cut yourself.
Magic Medicine is offline
Old 04-02-2006 | 08:58 AM
MOP
Lightbulb Re: Removal of exhaust gasket material
Using a thin coat of Hi Temp red silicone on both metal surfaces make the job a lot easier a sharpened putty knife is all you need, I have gone to using it at my risers joints without a gasket on my Gils. I let it cure over night before start up.
Phil
MOP is offline
Old 04-02-2006 | 09:56 AM
Kokopelli's Avatar
Thanks. Really looking forward to doing this all crunched up in the engine compartment.
Old 04-02-2006 | 05:50 PM
Tinkerer's Avatar
Next time use the Mr Gasket grafite gaskets. They just peel right off.
OH and they can be reused.
Tinkerer is offline
Old 04-02-2006 | 05:52 PM
Kokopelli's Avatar
I'll be sure to tell Mercruiser that.
