Sterling is testing the Rtech Twin Blower now! >
Old 04-03-2006 | 09:08 PM
Default Sterling is testing the Rtech Twin Blower now!
Just wanted to let you guys know that Sterling has started testing our twin blower system on one of their 557 Big Chief PSI engines. No full pulls yet, but I can tell you that the engine had 22 psi manifold pressure at just over 6000 RPM.
The intercooler dropped the air temperature from 290F down to 90F using 70F water. That's 90% efficiency at a very high lb/min of air flow. This temperature is before fuel and does not include the cooling effect from evaporation.
Total pressure loss from the bypass box to the intake manifold was only 2 psi including the throttle bodies and the intercooler core. We are still sorting things out (injector sizing, belts and pulleys) but will have more numbers soon.
Tom
Attached Thumbnails Sterling is testing the Rtech Twin Blower now!-sterling-email.jpg
tomcat is offline
Old 04-03-2006 | 09:25 PM
44MTI's Avatar
Default Re: Sterling is testing the Rtech Twin Blower now!
I'm confused, is Sterling Performance testing this system, or are You testing it on a Sterling Motor.
44MTI is offline
Old 04-03-2006 | 10:21 PM
Biggus's Avatar
I believe its being tested at Sterling on one of their motors.
Great news Tom!!!
Keep us posted!
Kurt
Biggus is offline
Old 04-03-2006 | 10:45 PM
Sean H's Avatar
A to Z
so is the pic the engine being tested? i also got confused on the mention of the chief headed PSI engine.... but i get confused easily....
Sean H is offline
Old 04-03-2006 | 10:59 PM
Strip Poker 388's Avatar
Rob
Tom Good luck and keep us posted
Strip Poker 388 is offline
Old 04-04-2006 | 08:12 AM
We are testing on Sterling's dyno using a Sterling engine. This was done to prevent any "confusion" about the HP being achieved. Also because their dyno is set up to datalog multiple temps, pressures and flowrates that I need to know.
The picture was taken after removal of the PSI blower; mocking up the twin blower installation. The mechanical fuel pump had to be relocated.
Sterling's PSI engine is a known quantity, 1500-1550 HP all day long at a known boost level. The purpose of the test is to see if we can safely increase that HP with more boost, better intercooling and lower parasitic losses.
tomcat is offline
Old 04-04-2006 | 08:21 AM
44MTI's Avatar
Thanks for the clarification. Good luck and let us know the results.
44MTI is offline
Old 04-04-2006 | 09:14 AM
RedDog382's Avatar
Is this why I'm still waiting for my motor freshening to be completed?
RedDog382 is offline
Old 04-04-2006 | 09:26 AM
Congrats!! I remember when this system was just a thought in your head!!
Pure Energy is offline
Old 04-04-2006 | 02:52 PM
PatriYacht's Avatar
Are we going to see this in the Bud Select boat soon?
PatriYacht is offline
