How fast does your...
Old 04-05-2006 | 01:01 PM
Default How fast does your...
cabin cool down when you run your air? I just tried out my new Mermaid 5200btu ac unit this weekend in the 353 and was a little disappointed. It ran straight for hours and never dropped them temp significantly. I put a digital thermometer in the supply vent and verified the temp at 64-65* (day). At night the supply temp got as low as 59* but it takes quite a while to drop that low. With an outside temp of 85* my cabin never dropped below 77*. Is this normal? I hear people tell me their ac will freeze them out, not mine? Should the unit be blowing cooler? Also, should the unit run for hours straight?
pwrbotr is offline
Old 04-05-2006 | 01:03 PM
Default Re: How fast does your...
Try a small DC fan near the vent to circulate the air. It sounds like the fan moving the air is not strong enough to circulate.
Blow-N-Thunder is offline
Old 04-05-2006 | 01:31 PM
Boomer 880's Avatar
My cabin cools down in a few minutes, once I turn on the AC.
Boomer 880 is offline
Old 04-05-2006 | 01:46 PM
BBB725's Avatar
Mine cools down in 10-15 mins
BBB725 is offline
Old 04-05-2006 | 03:22 PM
HiPerf2000's Avatar
mine cools down pretty quickly, but i have a 7500 btu with 2 supply vents.
HiPerf2000 is offline
Old 04-05-2006 | 03:36 PM
SOX's Avatar
SOX
Semper Fi
I don't have A/C on my boat but it sounds to me that you have a problem. A typical ac will put out at least 15 * cooler air than it's return. Possibly the problem is simply the return air is mixing with the hot outside air. If you can get to the condensing unit I would at least feel the larger line going into the compressor, it should be cold to the touch. If not you may have a problem. Also you may want to check your sea water lines for a strainer which may be plugged up.
If you have poor airflow typically the discharge air will be excessively cold this doesn't sound like the case unless the coil is froze up, then the airflow has been blocked by the ice. Try to turn the unit off for a few hours, try it again with the therm. and see what you get. If it has more airflow and a high temp. drop then you may be freezing the coil and need a tech. to check it out.
Good luck
SOX is offline
Old 04-05-2006 | 05:03 PM
AKA NoMoBoatin
I was told that my a/c would only be 10* below outside temp.i have a 5000 btu on the 37'
docmanrich37 is offline
Old 04-05-2006 | 05:28 PM
formula31's Avatar
12,5K in my 28. I can make it snow. Drops 25 degrees in a 1/2 hr with the fan all the way up.
formula31 is offline
Old 04-05-2006 | 10:24 PM
Semper Fi's Avatar
Sounds like you need to bring the boat to the dealer and let them figure out the problem. Hopefully it's under warranty.
Semper Fi is offline
Old 04-06-2006 | 05:36 PM
After talking with Mermaid tech support they said "if it blows 18-20* colder than the ambient temp, thats the definition of ac".
pwrbotr is offline
