For the outdrive Guru's(bravo 1)
Also..will a nosecone on a stock 454/385 mag cause you to lose top end speed...was on the boat when i bought it..If so...any idea how much speed it will cause you to lose...
Originally Posted by SED70
If you are running a bravo 1 with 1.50 gears...60mph....what speed would you be running if you changed to a 1.36 ratio...
1.36 drives are generally used on boats that have enough power to run close to or exceed 100mph...
Patrick
Patrick
I agree. Dont go to 1.36 gears until you run out of props for a 2.50 gear. If you are running a stock 454 magnum, dont even think about chnaging gears.
Originally Posted by checkmate454mag
I agree. Dont go to 1.36 gears until you run out of props for a 2.50 gear. .
The boat i bought had Big power in it and was running over 100 mph...when i bought boat stock Mag was put back in....Can i tell the gears without pulling the outdrive...I am atleast 5 mph slower that i should be with a stock mag motor and thats the only thing i can think that might be causing it......
Was Told i can turn the prop shaft 1 turn and watch how far the shaft moves ..is this correct..but what am i looking for...For example....if it is 1.5 and i turn shaft 1 turn..shaft will rotate 1 1/2 turn and if its 1.36 it will turn about 1 or so...Is this correct...
how about the nose cone...will it slow me down that much..Thanks
Are the gears in the upper or lower case if i have to have them changed
If you're boat's in the water and running, start calculating prop slip. You know the available ratios. You presumably will know your speed, RPM, and prop pitch. Do the calculation with each available ratio until you come up with a reasonable slip number. If you have 1.36 gears and do the math with a 1.50 ratio, you'll come out with about 0 slip... that means you don't have a 1.5 ratio.
