Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Older boat. Glassing over hull and deck joint like a Gladiator? >
Old 04-08-2006 | 10:53 AM
Steve_H
Default Older boat. Glassing over hull and deck joint like a Gladiator?
How is it done and can it be done to an older boat?
Old 04-09-2006 | 07:12 AM
glassdave's Avatar
Neno the mind boggler
Default Re: Older boat. Glassing over hull and deck joint like a Gladiator?
yes it can be done to just about any boat. to do it properly you should be able to access all of the seam from the inside as that is where you can get you best strength. you will need to lay about a foot wide tab around the perimiter on the inside over the seam. you will also need to grind that area to get a good mechanical bond. the outside really depends on the shape of the lap joint as to how you should fair it out. what are you working on?
08 OPA High Points Champion
glassdave is offline
Old 04-09-2006 | 08:23 AM
Steve_H
Thanks Dave. not working on it yet. just future plans. sounds like its a pretty big deal to do and i dont have much of a budget.
Old 04-09-2006 | 09:06 AM
glassdave's Avatar
probably would cost a few hundred dollars in materials but boat would need a complete (pretty much) paint job after its filled. i always thought it would be pretty cool to do up an old 27 sport magnum like a gladiator.
ratman
10-09-2006 09:22 PM
muffman
11
01-23-2006 08:20 PM
Prater
7
09-23-2005 06:29 AM
Cord
1
04-19-2004 09:30 AM
Wildfire
3
02-19-2004 06:46 PM
