Hitch question for H2 with rear mounted tire? >
Old 04-11-2006 | 06:56 AM
Jimmys 288's Avatar
Default Hitch question for H2 with rear mounted tire?
Anyone out there have an H2 with a rear mounted tire? If so, have you found a hitch that is long enough to clear the tire so that I don't have to move the tire up? Also, was it rated high enough? If so, where did you get it?
Any help is greatly appreciated!!!!
Thanks!
C-
Jimmys 288 is offline
Old 04-11-2006 | 07:06 AM
dean51267's Avatar
Default Re: Hitch question for H2 with rear mounted tire?
I tried, no luck... have a internal tire rack and wanted an extrenal, looked for trailer hitch I could tow a 33' with twins with, no luck, stayed with internal tire.... if you fine one please pass info long... thanks!
dean51267 is offline
Old 04-11-2006 | 04:37 PM
DJF
Go to putnamhitch.com
Look under products and go to ball mounts. They have draw bars that have over a 12" shank (distance between pin hole in receiver and mounting hole for ball).
Dave
DJF is offline
Old 04-11-2006 | 04:59 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
If you are going with something like that; with an extended shank, watch as it probably drops the weight capacity well below what you are looking for. My hitch setup has two holes to slide in your hitch pin. The one with the ball closest to the truck is 12K rated. The hole with the ball farther out away from the truck; by 2 inches, is rated at only 10K. This is a WD hitch setup with a two piece drawbar. You may find something like this that will work, but you have to look at the very very fine small print stamped in the side of the drawbar shank to know any of this.
Sydwayz is offline
Old 04-11-2006 | 05:07 PM
carrboy's Avatar
Sell you my hitch...just sold the H2... i pulled a 31 Sonic with the hitch.
Attached Thumbnails Hitch question for H2 with rear mounted tire?-dsc00621-small-.jpg
carrboy is offline
Old 04-11-2006 | 08:14 PM
I use a 4 inch drop . works fine
chad1 is offline
Old 04-12-2006 | 07:34 AM
Jimmys 288's Avatar
Thanks guys! I really appreciate all the help! I will let Jimmy know.
Carrboy - I'll be in touch. How much do you want for it? Have any details you can give me on it?
Thanks again. I really appreciate it. You are helping out the girlfriend who is just trying to help!!!
C-
Old 04-12-2006 | 01:08 PM
Jimmys 288's Avatar
Chad1 - How long is the hitch that you are using?
Thanks,
C-
Old 04-12-2006 | 08:37 PM
standard length.Its a 6 inch drop..gives me just enough room
under the tire to lock the hitch on the trailer.The onboard compressor keeps
it level...does anyone use a supercharger. these h2 s could
use some more power.
chad1 is offline
Old 04-12-2006 | 09:12 PM
carrboy's Avatar
I know a guy with the supercharger but it's still not enough when pulling a large boat.That's why I sold mine and a duramax dually sits in it's place.
carrboy is offline
Donzi Corleone
13
02-02-2008 12:33 PM
jayhawk261
8
03-17-2007 02:41 PM
Horseplay
01-11-2004 07:34 AM
Intolerant1
12-29-2002 01:25 AM
Nordicflame
19
12-06-2002 10:24 AM
