Reversion what is the impact? >
Old 04-11-2006 | 10:11 PM
Rage's Avatar
Default Reversion what is the impact?
As I understand it reversion in general terms is the sucking of 'sea' water into the exhaust pipe outlets due to certain cam design parameters. That is not the question.
What are the actual proplems that reversion causes?
1.) Corrosion only?
2.) Hydraulic lock of pistons?
3.) Other????????
Rage is offline
Old 04-11-2006 | 10:15 PM
Vinny P's Avatar
I hate the winter!!
Default Re: Reversion what is the impact?
Corrosion for sure, if bad enough it can hydrolock the engine. It can make the exhaust valves brittle enough to snap off. Water can get into the oil wiping out the engine. The list goes on..
Vinny P is offline
Old 04-11-2006 | 10:20 PM
articfriends's Avatar
Worst case scenario-the water hydro locks the piston,bends or breaks the connecting rod destroying the motor,more likely though,water quenching the exhaust valve makes it brittle then head breaks off stem then destroys the motor. Mild reversion-milkshake oil,rust and pitting in affected cylinders,Smitty
articfriends is offline
Old 04-11-2006 | 10:22 PM
check,you beat me while i was typing,Smitty
Old 04-11-2006 | 10:29 PM
tomtbone1993's Avatar
i lost 2 engines last year to it
tomtbone1993 is offline
ratman's Avatar
vrooom vroom bang! got the picture...with reversion the engine will be very short lived. run dry exhaust and forgedaboutit
ratman is offline
Old 04-11-2006 | 11:05 PM
Rage's Avatar
Son of a gun! Almost sorry I asked.
Does the hydraulic lock happen in a middle of a run lets say or upon start up after turning the engine off and restart?
What's the best/easiest way to find out if you have a reversion issue?
Rage is offline
Old 04-11-2006 | 11:35 PM
nordic95's Avatar
What exhaust are you running and what cam.I was told by my exhaust manifold company to run the motor at idle for ten to fifteen minutes with my quit system in the closed position.Then shut off engine and remove riser and see if the manifold is wet inside.If it is then you have trouble.
Nordic95
nordic95 is offline
Old 04-12-2006 | 08:58 AM
Nordicflame's Avatar
Sorry Bill
I had to warn you though....
It's well worth checking for peace of mind.
Nordicflame is offline
Old 04-12-2006 | 09:49 AM
Rage's Avatar
Originally Posted by Nordicflame
Sorry Bill
Please do not appologize. This is need to know stuff.
Since my o2 wide band sensor survived a 12 min. run with a lot of idling I am hopefull BUT will still conduct tests suggested.
The cam timing @0.050 is....
- intake opens 6.0 BTDC
- intake closes 44.0 ATDC
- intake duration 230
- exhaust opens 57.0 BBDC
- exhaust closes (1.0) BTDC
- exhaust duration 236
The exhaust is stock Merc 496HO with turbulators removed.
Rage is offline
