Question for 36 outlaw owners >
Old 04-13-2006 | 04:04 PM
BajaRunner's Avatar
Default Question for 36 outlaw owners
Where do you trim to on your trim indicators to get the max speed. I seem to have to trim WAY too much.
BajaRunner is offline
Old 04-13-2006 | 04:10 PM
baja36ft's Avatar
Default Re: Question for 36 outlaw owners
What's Way To Much? I Trim At 5 Or 6 If You Have The Deeper X You Will Have To Trim Some Were Off The
Meter.
baja36ft is offline
Old 04-13-2006 | 04:16 PM
baja36ft's Avatar
Did You Find A Set Of 28 Pitch Props To Try Yet??
baja36ft is offline
Old 04-13-2006 | 05:03 PM
BajaRunner's Avatar
Im trimming to 9+ off the meter! after 8 or so, i feel a little vibration like im trimming it too much. it never blows out and still increases, i just dont want anything to break!
The 28's are in. might try em this weekend.
Old 04-13-2006 | 05:15 PM
I seem to be best around 7, much more and I start getting air
crmotors is offline
Old 04-13-2006 | 06:06 PM
baja36ft's Avatar
IF YOU WANT TO SELL THE 26'S I HAVE SOMEONE THAT WANTS THEM.
baja36ft is offline
Old 04-13-2006 | 07:42 PM
Bajarunner,
I have found that with my 4 blades on a 1999 with the " deep X" that I do not need as much trim as I did with the previous 3 blades. General cruising the best setting is at "neutral" plus or minus approx. a half pin on the guage. As far as for top speed goes around 6 to 7 for the way I am set up.
If you are feeling vibration that is a sure sign that you have over trimmed. Bump it back done a tad.
Best bet is to experiment with a GPS and your particular set up to see what is best for you.
Mark
GETTINBYE is offline
Old 04-14-2006 | 07:25 AM
Dock Holiday's Avatar
Charter Member #34
The 36 DOES require a lot of trim.
I would not compare the trim indicator numbers too much because every boat is just a little different. You can adjust the actuators on the trim cylinders which will result in different readings.
We had problems with the stock set up and I went with an after market unit and I'm still not too pleased with it. If I had it to do over I would have bought the complete setup from Stainless Marine that reads off the top of the drive.
But I do have to bury the indicators (lots of trim) to get her rolling!
Dock Holiday is offline
Old 04-14-2006 | 07:53 AM
BajaRunner's Avatar
Im wondering if i need more cup. my current props have almost none. im wondering if im compensating for the lack of cup.
Old 04-14-2006 | 10:11 AM
Charter Member #34
I would call Julie or Matt at Throttle up and work out the prop with them.
Make sure you have some good hard numbers as for speed, RPM, etc and that along with the type and size of the boat will tell them what they need to get you dialed in.
I did try a set of 28's last year that they labbed for a stepped hull boat with no cup and WOW, the slip was off the charts.
You do need some cup on your setup. But too much will show you down and will also be hard on your drives, especially when you launch and re-enter.
Good luck
