Bravo One Drives Stuck >
Old 04-13-2006 | 10:32 PM
johnnywhip's Avatar
Default Bravo One Drives Stuck
Just bought a used Fountain. Was testing drives and they went up and down from throttle switch Ok, then tried port, OK, then star, OK, then both switch and they stopped, and now they are stuck up..clicking sound when I use any switch but drives don't move. I'm new to powerboats as you can tell..been driving that twin screw Sea Ray to long!
johnnywhip is offline
Old 04-13-2006 | 10:41 PM
Ted G's Avatar
Default Re: Bravo One Drives Stuck
May have popped the fuse to the trim motor or you have a bad ground. The clicking you here is the relays closing.
www.cbpba.com
Ted G is offline
Old 04-13-2006 | 11:03 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Both drives ....... Batteries low?
US1 Fountain is offline
Old 04-13-2006 | 11:10 PM
johnnywhip's Avatar
Batteries up, not low..thanks!
Old 04-13-2006 | 11:14 PM
johnnywhip's Avatar
And yes both drives stuck up...up and down fine from throttle switch, then each Ok but when I went to both switch they stopped.,..when I push any swith I hear a clicking , but no movement???
Old 04-14-2006 | 06:45 AM
Mbam's Avatar
Offshoreonly Advertiser
If it's an older boat if I remember correctly there is a breaker on the bulkhead in the back. It's not big enough to run both pumps at once. I think it's under/behind the seat, or maybe in the engine compartment. It's been a while
Mbam is offline
Old 04-14-2006 | 07:02 PM
johnnywhip's Avatar
Smile Re: Bravo One Drives Stuck
Thanks!! Mbam it was the breakers under the rear seat!
CCPerformance
8
08-29-2005 10:00 AM
Joyride
3
07-31-2005 06:27 PM
terrygar
3
07-03-2005 10:58 PM
tripps
2
05-11-2004 09:51 PM
LVFASTCAT
5
08-19-2003 08:05 AM
