what type of fuel pump r u running on your 1000+ hp engines >
Old 04-16-2006 | 03:18 PM
ratman's Avatar
Default what type of fuel pump r u running on your 1000+ hp engines
im going to run some big mechanical fuel pumps on my blower motors but want to run electric pumps in parrallel so if a mech pumps fails im still good to go and wont melt down an engine. what type/model and brand of electric fuel pumps are you guys with big power running? thx, rm
ratman is offline
Old 04-16-2006 | 03:31 PM
Default Re: what type of fuel pump r u running on your 1000+ hp engines
I run all Aeromotive fuel systems on my big HP engines or a belt driven mechanical fuel pump such as a BG or Ron's . Both using returns.
Dean Gellner
mrhorsepower1 is offline
Old 04-16-2006 | 04:37 PM
ratman's Avatar
dean i dont have bungs in my tanks for returns, will the big aeromotive a1000 pump work ok with a regulator and no return? thx, rm
ratman is offline
Old 04-16-2006 | 05:13 PM
TeamSaris's Avatar
Driver-441
Racer
We run aeromotoive too. Or sometimes Peterson
TeamSaris is offline
Old 04-16-2006 | 05:31 PM
Must run return line. The purpose of returning the fuel eliminates "dead heading" of the regulator and provides constant and stable fuel pressure , at idle and WOT. You will eliminate fuel pressure drop by going with this system and the possibilty of leaning out the engine.
Old 04-16-2006 | 05:32 PM
JCPERF's Avatar
You can run Weldon pumps with no return that can be boost referenced.They can come on when you make a pound of boost or more.This can eliminate dead heading problems like Dean said.They only work when the motors are pulling fuel.
JCPERF is offline
Old 04-16-2006 | 05:47 PM
RMPRam's Avatar
I've got 1100hp PSI supercharged motors in my 38 Cigarette. Each of my 2 tanks has a -12 (3/4") hose that feeds my fuel filter. I then "T" with one leg, in -10 (1/2"), going to a modified mechanical pump on the motor and continuing to the fuel log with -10. The other leg of the "T" goes to a Weldon electric pump, activated by boost pressure (4 lbs.), with -10 hose going to a one way valve @ the fuel log.
I have a return pressure regulator @ the fuel log to return fuel to the tank, that is -10 hose.
This system works very well in that if you are cruising and not in boost, the el. pump is not running. I've run this combination for 4 years with no trouble.
RMPRam is offline
Old 04-16-2006 | 06:39 PM
LapseofReason's Avatar
I run the Carter mech. pump and a Mallory elec. But I only have 850hp.
LapseofReason is offline
Old 04-16-2006 | 06:52 PM
TeamSaris's Avatar
Driver-441
Racer
only??
Old 04-16-2006 | 06:56 PM
375stinger's Avatar
we run aeromotive a1000s with 555c.i. approx 960 hp, 8lb boost
375stinger is offline
