Tire size
Old 04-17-2006 | 08:38 PM
Default Tire size
What is the biggest tire I can fit on a 2005 F350 without lifting it and what kind of height would it gain?
sonic700 is offline
Old 04-17-2006 | 08:51 PM
Registered User
Default Re: Tire size
315- 17 (Hummer H-2) with very minor trimming on the bottoms of the inner fender pieces. They're plastic.
Chris Sunkin is offline
Old 04-17-2006 | 09:22 PM
The truck sits on LT 275/70 R18 from the factory.
sonic700 is offline
Old 04-18-2006 | 09:33 AM
From: A tree somewhere in the woods in Clarcona Fl.
If you'll put a 2 inch leveling kit on the truck you can put a set of 35" tires under it without any trimming, the 2" leveling kit(oversized coil spring insulators) also doesn't change alignment angles and are cheap. All you'll need to do is have the steering wheel re-centered. I'm just now finishing one for a customer.
Slick02 is offline
skopi55
6
02-20-2007 07:46 PM
Vyper340
10-10-2006 09:15 PM
BajaRunner
13
09-08-2006 06:52 AM
plumbers crack
1
07-30-2006 08:25 PM
Hauling Trash
05-09-2003 06:01 AM
