water in v-berth 1994 outlaw 24 Help!!! >
Old 04-19-2006 | 10:58 PM
jeff32's Avatar
Default water in v-berth 1994 outlaw 24 Help!!!
Anybody knows how to stop the water from filling the nose of water under the last cushions ? No holes to drain there... the only place I think the water comes from are the pop up cleats. Do you guys have a hole in this triangular place to drain it ? What do you think is leaking?
Thanks for the help!
jeff32 is offline
Old 04-20-2006 | 09:00 AM
Default Re: water in v-berth 1994 outlaw 24 Help!!!
Check for ample caulking around cleats, bow light, and horn. It seems at times there is a "caulk shortage" at the factory that can lead to the symptoms that you describe.
Easy fix just pain in the azz.
Mark
GETTINBYE is online now
Old 04-20-2006 | 08:57 PM
There should be scupper drains for the nose cleats. Sometimes the drain hose for the scupper can come off and dump water into the nose bulkhead area.
pwam1 is offline
Old 04-20-2006 | 09:34 PM
Smitty's Avatar
The same happened on my Outlaw. The hose came off the drain fitting and it filled up the bow area with water. Take off the cover panel and take a look.
Smitty is offline
Old 04-21-2006 | 09:49 PM
AIR TIME's Avatar
Thumbs down Re: water in v-berth 1994 outlaw 24 Help!!!
HOPE YOU DON'T GET THE CORING WET .DELAM WILL HAPPEN NEXTED . BEEN THERE
AIR TIME is offline
Old 04-21-2006 | 11:50 PM
jeff32's Avatar
thanks guys! I'll take a look.
jeff32 is offline
CAPTAIN CHUCK
04-14-2007 11:57 AM
rlv1017
05-22-2006 09:23 PM
Steel Outlawed
Baja
13
12-09-2004 08:40 PM
ROADHOG
Sonic
15
07-18-2004 02:59 PM
