Go Back  Offshoreonly.com > Race Talk > General Racing Discussion
wanted: dry sump #6's >
Old 04-20-2006 | 12:50 PM
Registered User
Default wanted: dry sump #6's
I'm looking for s set of dry sump #6's with transom assembly's 1:36 gears.
twistman is offline
Old 04-20-2006 | 02:38 PM
cougarman's Avatar
Default Re: wanted: dry sump #6's
I have two Drive line Transome assemblys that will be ready for a buyer in about two weeks, for # 6's.
Also have one #6 drive although it's wet sump so probably of no use to you. 1.5 gears.
Cougarman
cougarman is offline
Old 04-21-2006 | 05:59 AM
drypipetiger's Avatar
http://www.offshoreonly.com/esvon/page-10016.html
drypipetiger is offline
Old 04-21-2006 | 07:23 AM
Registered User
cougarman do you have a price in mind?
twistman is offline
Old 04-21-2006 | 08:40 AM
cougarman's Avatar
Price for which parts? T/A's or the drive? Or all of it?
Far as the Transome assemblys I went through a lot of work to make them Brand new. I completly stripped them, had them redipped in Alodine same as Mercury used on them to protect them from corrosion. It's a chromate, then repainted them, all new bearings, repolished all the stainless pieces. (your cylinders & the two inch heads of all the pins for the pivot points) and new stickers.
Cougarman
Old 04-21-2006 | 09:59 AM
Registered User
cougarman can you pm me with your number? i am interested in drives and transom assembly's as a pair.
twistman is offline
Old 04-21-2006 | 11:11 AM
cougarman's Avatar
You are aware I only have (one) #6 drive ! Right Hand
And I have (Two) T/A's.
Cougarman
Machz1000
03-07-2007 08:11 AM
TeamPSI
6
02-01-2007 10:13 AM
JCPERF
02-22-2006 09:48 PM
SLINGSHOT
07-12-2002 04:55 PM
