500 EFI losing rpm's >
Old 04-24-2006 | 09:15 AM
Steel Outlawed's Avatar
Default 500 EFI losing rpm's
I had the port engine rebuilt over the winter. It's a 500 efi, and when I take it up over 4000 rpms it will top out at 4500-4600 then start losing rpms. I can back it down below 4000 for a few seconds then take it back up and it does it again. I have changed the fuel water seperator filters. Just looking for suggestions where to go next. I will probably hook a fuel; pressure gauge up next to see what pressure I get.
Steel Outlawed is offline
Old 04-24-2006 | 10:17 AM
Default Re: 500 EFI losing rpm's
Check fuel pressure. That is most likely the problem. Be careful, if it is pulling RPM it is because it is detonating!!
TxHawk is offline
Old 04-24-2006 | 08:21 PM
i agree sounds like a fuel problem 4 sure
rssteiny is offline
Old 04-24-2006 | 08:28 PM
Have You Changed The Silver Filter At The Top Rear Of The Motor?
chad1 is offline
Old 04-25-2006 | 06:03 PM
Strip Poker 388's Avatar
Rob
Also is the other motor only going to 4600? if so you need to buz it higher after you find the problem.Its Proped wrong.
Rob
Strip Poker 388 is offline
Old 04-25-2006 | 06:05 PM
Last year they would run up to 5000+. So it's something that has happened since the rebuild.
Old 04-25-2006 | 10:46 PM
Rob
So both motors are not turning up???
Is all the fuel system stock 500efi stuff???
Old 04-26-2006 | 10:44 AM
lucky strike's Avatar
I had the same problem last year with a 525efi.
There is a sensor assy on the crankshaft pulley mine was part #828358 2.
I would run wide open then it felt like I was rumming out of gas. I'd slow down for a while then it would be ok. It happened twice on poker runs.
Changed the sensors and never had the problem again
Steve
lucky strike is offline
Old 04-26-2006 | 10:46 AM
Oh ya I changed those filters first--- still did it !
Old 04-26-2006 | 12:31 PM
Rob
Steve
Steve the 500efi doesnt have a crank trigger like yours.
