What is the Best Engine Flushing System >
Old 04-27-2006 | 04:44 PM
Default What is the Best Engine Flushing System
What are and where do you get relaible, well built installed engine flushing systems for high horsepower engines?
I am looking to add engine flushing to my closed looped cooled system so that I can flush the drive and engine with Salt Away when it's on my boat lift.
PM or respond on this thread with pics and places to get one.
Thanks!
Vyper340 is offline
Old 04-27-2006 | 04:55 PM
GOODT's Avatar
Default Re: What is the Best Engine Flushing System
I like the perko system with the check valve for bravos
GOODT is offline
Old 04-27-2006 | 05:18 PM
Poorsche's Avatar
I added a system to my closed cooling system on my Formula 357SR1. I had Perko strainers and installed their caps with the hose fittings on them. Also hooked similar fixtures to strainers for genset and a/c system.
I got a brass manifold type thing that let me control which device got flush water and gave me a single hose contact. Other benfit was I was able to break airlock on a/c and genset after boat had been in stack storage in addition to being able to run on workstand.
Also put brass cut-offs in line to force water theu engines rather than letting it go out the transom.
Poorsche is offline
Old 04-27-2006 | 11:05 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Vyper,
Give me a ring or email tomorrow. I have 496s and added an unrestriced T before the SWP. Turn the hose on, and it flushes the drive. Turn the motor on, and flush the motor. Turn the motor off, and flush the the drive again until you turn off the hose.
Works great, last long time.
Sydwayz is offline
Old 04-28-2006 | 06:03 AM
Brian - you have mail...
Vyper340 is offline
Old 04-28-2006 | 07:26 AM
BillR's Avatar
OSO Moderator
Originally Posted by Sydwayz
Vyper,
I've been telling him the SAME thing for 2 weeks.
at the bottom:
http://www.livorsi.com/catalog/sea_strainers.htm
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 04-28-2006 | 07:04 PM
99fever27's Avatar
Vyper,
Ditto..built my own this week works great out of the water...true test will be IN the water tommorow.
99fever27 is offline
Old 04-28-2006 | 10:50 PM
99fever27's Avatar
http://www.marinetechgroup.com/partsdrawing.htm
try here too just found this..
99fever27's Avatar
http://www.marinetechgroup.com/flushvalvephotos.htm
Buster
14
09-16-2007 10:46 AM
formula1
01-06-2007 10:27 AM
Stormrider
15
06-02-2005 08:07 AM
gripit
12
05-04-2005 05:24 AM
