Water Pump Loosing Suction
I start the motor, couple minutes goes by , starts to pump water out the headers. stops, comes out the right , comes out the left then stops. Could a leaking sea strainer cause this or strainer gasket ? Its obvious im loosing suction .No clogs or kinks in any hose. New impeller. New water hose also.
Any leak in the intake side could cause it and so could a scored pump housing. How did it look when you were replacing the impeller??
Rage
6
07-31-2007 09:45 AM
