first day back out on the water! >
Old 04-30-2006 | 04:18 PM
johnnyboatman's Avatar
Default first day back out on the water!
Today took the boat out to a local lake and everything was going good.... broke her over on plane ran her up to about 100 the right motor just acts like it shifts into neutral thinking i blew an outdrive or something i turn the motor off. get to the ramp and start the motor back and check to see if goes in reverse and it does.... it will go in reverse and neutral but no forward.... got home and i
took the cap and back off of the drive when i got home and there is not metal shavings anywere.... and its not the cable(already checked that)! has anyone expierienced this or know anything about wat could be wrong?
thanx,johnny
johnnyboatman is offline
Old 04-30-2006 | 04:38 PM
TeamSaris's Avatar
Driver-441
Racer
Default Re: first day back out on the water!
right motor?? Starboard If you run trannies it may be those slipping.
TeamSaris is offline
Old 04-30-2006 | 09:13 PM
no trannys , bravo drives
Old 04-30-2006 | 09:27 PM
NJSONIC's Avatar
Could be one of the clutches,the upper shaft. Hows your shift cable-adjustment?
NJSONIC is offline
Old 04-30-2006 | 10:05 PM
shift cable seems fine, it quit pulling at about 85mph acts like it went to nuetral,reverse is fine, no metal or chunks? pulled the drive off and its hard to turn from the drive shaft turns so far and stops turn the other way same thing, it will turn but you have to force it to turn. 1 have a spare so where fixin to install it this week and tear down this one to see what happened.
Old 04-30-2006 | 10:15 PM
R Addiction's Avatar
AT Cult Member #3
Luckily she didn't lock up or blow up.....
R Addiction is offline
Old 05-01-2006 | 09:00 PM
tore it down broke the bottom off the forward gear be glad when my other lower from bmax is done so i can put those on and hopefuly not have any drive issues. i need to put i piece of wood between the throttles to keep my heavy hand out of it.
h2oboater
Classic Offshore
801
02-01-2022 03:21 PM
Smarty
Classic Offshore
39
07-09-2008 06:20 PM
nitrousnolan
Poker Runs and Boating Events
2
07-18-2007 11:24 AM
Wally
01-15-2003 03:27 PM
