Looking for 5th wheel trailer >
Old 05-04-2006 | 08:17 AM
vagrant's Avatar
Charter Member #37 /Moderator/Platinum Member
Default Looking for gooseneck trailer
I am looking for a gooseneck trailer for my 42 Sonic. I have a 2yr old tri-axle myco that I could trade.
David
Champagne taste on a beer Budget
C. P. B. A. Carolina Power Boat Assoc
vagrant is offline
Old 05-04-2006 | 09:31 AM
Default Re: Looking for 5th wheel trailer
theres one in the swap shop
kickin32 is offline
Old 05-04-2006 | 10:47 AM
Papache's Avatar
Registered User
Default Re: Looking for gooseneck trailer
David
p.apache has one give me a call 609-839-1392 paul
Papache is offline
Old 05-04-2006 | 02:05 PM
Jayl13's Avatar
Your Myco have a drive guard?
Jayl13 is offline
Old 05-04-2006 | 02:55 PM
kr1276's Avatar
I am looking for a trailer for my 442. What are the specs on your trailer.
Keith
kr1276 is offline
Old 05-04-2006 | 02:57 PM
Jayl13's Avatar
I have a loadmaster aluminum I beam 2005, Torsion axles, brakes on all 3 axles. Looking to upgrade trailer for the apache. Will fit 40-44 ft boats. Trailer overall is 47 feet
J
Jayl13 is offline
Old 05-04-2006 | 03:45 PM
kr1276's Avatar
Jayl13,
brakes disc or drum? Electric or Hydraulic? Type wheels and tires?
rated capacity?
I have been advertising in the wanted section for months and have had no responses at all.
Keith
kr1276 is offline
Old 05-04-2006 | 03:55 PM
Jayl13's Avatar
Disc brakes all the way around, Hydraulic I believe. If this thing can hold an apache (should be rated at 18 K lbs, it should hold a baja. dry weight of my apache I believe is 13500, loaded im pushing upwards just over 15K so its fine.
Attached Thumbnails Looking for 5th wheel trailer-dscn3218.jpg   Looking for 5th wheel trailer-dscn3223.jpg
Jayl13 is offline
Old 05-04-2006 | 03:59 PM
Reindl Powerboats's Avatar
I have a MYCO true 5th wheel trailer that we have never used at all.
Call for information, (513) 706-3199, Chris Reindl
Reindl Powerboats is offline
Old 05-04-2006 | 04:03 PM
Jayl13's Avatar
David
Got a picture of your myco by chance? Did the bumper pull myco present any problems for you cause of the size or weight of your boat? Or is it you just want to go to gooseneck for stability and maneuverability reasons? Mark Adams has a full myco gooseneck for 13 K for a tractor, has air brakes on it. I cant use it, I need regular brakes for my F350 dually.
J
Jayl13 is offline
