SuperV's engines
Old 01-18-2002 | 09:33 PM
Post SuperV's engines
How's the engine working going Crazyhorse?
BGIII is offline
Old 01-18-2002 | 09:42 PM
Crazyhorse's Avatar
Post
I think we're going to run the first one Monday or Tuesday. Depends on when the MSD shows up. Got it pretty much buttoned up today.
Crazyhorse is offline
Old 01-19-2002 | 08:41 AM
Post
What all did you end up doing on them Dave?....Fred
fred is offline
Old 01-19-2002 | 08:42 AM
Post
Are they getting dynoed?...if so let us know the numbers....Fred
fred is offline
Old 01-19-2002 | 11:29 AM
Crazyhorse's Avatar
Post
Fred, good to hear from you. No, we're not going to dyno them, just run for cam break-in. Bored +.030, decked, align-honed, balanced, resized the rods w/ARP bolts, Federal Mogul cams (same as Dyno's and Waterfoul's), Cloyes timing chains, new valves, springs, retainers, and keepers in the Merlin heads, L2465F TRW+.030 pistons. Any progress on the Eagle? It's a great boat.
Old 01-19-2002 | 11:50 AM
Post
Showed my boat yesterday....have to have it gone before I can move anywhere on the Eagle...(wifes rule)the Eagle is sitting ...waiting for me to fall prey on it!....Fred
fred is offline
Old 01-19-2002 | 11:52 AM
Post
Those motors should be plenty for superv's boat, it was prety fast with the old set-up...Fred
fred is offline
Old 01-19-2002 | 12:00 PM
Crazyhorse's Avatar
Post
We went from 8.75 to 9.7:1 compression ratio but the cam is a little less than the Bulldog cams he had last year. It should run about the same but the valve train should last longer as the springs are set at 110 lbs closed. Good luck on selling the 30. It's a good boat and should be about bulletproof for the next owner. You going to be in rack storage at GLM this year?
[ 01-19-2002: Message edited by: Crazyhorse ]
Old 01-19-2002 | 06:54 PM
Crazyhorse's Avatar
Post
I think KAAMA is running Ultradynes.
Old 01-19-2002 | 07:50 PM
Tinkerer's Avatar
Thumbs up
I have run ultradyne cams for about 10 yrs. now. I haven't had any problems other than my own fault.
Tinkerer is offline
