xr drive reservor empties >
Old 05-07-2006 | 08:19 PM
Default xr drive reservor empties
reservor seems to be pressuring up and blowing all fliud
out.
chad1 is offline
Old 05-07-2006 | 09:19 PM
Vinny P's Avatar
I hate the winter!!
Default Re: xr drive reservor empties
How much fluid comes out? Are you filling it too much ? When hot, the fluid will expand and fill up the bottle.
Vinny P is offline
Old 05-07-2006 | 09:24 PM
All Of It...i Filled It Back Up To The Add Line And It Blew Fluid All Over Again.
chad1 is offline
Old 05-08-2006 | 08:16 AM
Mr Gadgets's Avatar
Charter Member #601
Drive shower? Is this heat related?? A hard pass to make it happen or just short cruise?? How full do you fill your drive?? or I should ask what proceedure do you use to fill it? Fill up to the vent on top and put the plug in, then fill til you see it in the reservoir??
Tell us exactly what is happening.. maybe we can figure it out..
Mr Gadgets is offline
Old 05-08-2006 | 09:48 AM
GOODT's Avatar
If its comming out like that then you have a bearing issue, thats the only way it will get hot enough to do that I have seen it 100s of times
if I had to take a guess site un seen pinion bearing, 7 out of 10 times thats what it is
get someone that knows xrs to look at it ....DO NOT RUN THE BOAT!!!!!!
GOODT is offline
Old 05-08-2006 | 10:02 PM
Found The Problem
When Adding Fluid Last The Gasket In The Cap Fell Out. I Found It Today On Top Of The Battery...
Learn Something Everyday..
chad1 is offline
Old 05-08-2006 | 11:26 PM
It still should not blow ALL the fluid out of the bottle.
Griff is offline
Old 05-09-2006 | 05:39 AM
GOODT's Avatar
VERY TRUE
GOODT is offline
Old 05-09-2006 | 08:53 AM
Put The Gasket Back In And Ran The Boat Hard.no Fluid Loss.im Gonna Make A Drive Shower Off The
Innercooler Water Dump Passage. Im Sure THE DRIVE IS Also Heating Up..running Merc Hp Oil...some One Said The Royal Purple Will Run Cooler.any Truth?
Thanks.
chad1 is offline
Old 05-09-2006 | 12:28 PM
GOODT's Avatar
ROYAL PURPLE is a 0 friction lube I dont recomend it for bravos as they use friction to shift, also if you are still under warr it will void the warr
GOODT is offline
