Do HP500's Need Thermostats??? >
Old 05-08-2006 | 09:43 PM
Default Do HP500's Need Thermostats???
Do 2000 carb HP500's need thermostats?
ActiveFun is offline
Old 05-08-2006 | 11:27 PM
Default Re: Do HP500's Need Thermostats???
Yes. Keeps temps and power consistent.
Griff is offline
Old 05-09-2006 | 08:04 PM
BajaBennett's Avatar
If they are fuel injected-------YES! The ECM takes temp readings and adjust the fuel mix.
Dail
BajaBennett is offline
Old 05-09-2006 | 09:26 PM
MOP
Some of the best running engines are closed cooled running at 180 degrees. It is important to bring the engine to a good operating temperature, it brings the oil up to its proper temp range, makes for better combustion which makes power, helps to eliminate condensation in the engine, and bring the engines parts into tolerance.
MOP is offline
Old 05-09-2006 | 09:57 PM
ctadams21's Avatar
Mine (carb motors)do not have thermostats or circ water pumps. Just have the crossover and sea water pump. They run very cool. When I tried to put the t-stats in the pressure blew out the housing gaskets.
Is my setup wrong? I really would like to get a little temperature in these things.
ctadams21 is offline
Old 05-09-2006 | 10:03 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
You have no bypass hose then.
Do a search. This is one of the more common topics.
US1 Fountain is offline
Old 05-10-2006 | 07:23 AM
PatriYacht's Avatar
You will need to change the crossover and thermostat housing to the kind that have a bypass hose. Without the bypass, block water pressure will be very high and no water will go through the exhaust, resulting in burnt exhaust hoses.
PatriYacht is offline
Old 05-15-2006 | 10:51 AM
ctadams21's Avatar
Here's an interesting Bypass valve I found that is built into the t-stat housing:
http://www.rexmar.com/page160.html
After reading old posts on this subject I am still not sure of one thing. Do you really need a check valve in the system or can the pressure just be relieved by bypassing to a 3 port t-stat housing (which circulates the water back out the exhaust when t-stat is closed)?
Old 05-26-2006 | 04:47 AM
ctadams21's Avatar
I have a pipe plug on top of my thermostat housing. I think there is also a plug on the coolant passage of the Dart Intake.
Could'nt I replace the plugs with fittings and just run a 3/4 hose from the passage port to the top of the t-stat housing? That would bypass water past the t-stat and go out the exhaust. Would it flow enough?
CTA
GS42fun
4
01-26-2006 05:23 AM
ctadams21
5
10-24-2004 05:32 AM
Crazyhorse
04-21-2003 08:36 AM
guillermof
14
11-29-2002 05:14 PM
dyno
13
06-24-2002 10:04 AM
