Must see video clip...
That clip has been around for some time now...
It does makes you think....
But you can also think just how hot 5300 gallons of lit fuel can be.....
Originally Posted by Waterboy123
...but it makes you ask some questions,...
Adjust your aluminum beanie and stop chewing on tin foil.
I mean no offence to victims and there families of 9/11 by posting the following clip but it makes you ask some questions, You will have to view it quickly before it gets pulled down....
http://www.pentagonstrike.co.uk/flash.htm#Main
What does this have to do with OFFSHORE Power boating?
Do I smell "SuperCrash" trying to get back on OSO?
Dean
BS!!! Pure BS!!
There was wreckage in the building. I believe one engine was found burried. There is an impact point in the grass indicating the aircraft hit the ground first and bounced before striking the building.
As anyone that works with aluminum knows, it will burn if the fire is hot enough. Most of the wreckage was probably consumed by the fire.
If you don't believe me, search for reports of the HMS Shefield that was struck by a French missile and burned for days. The ships superstructure was aluminum.
The plane that crashed in Pennsylvania that same day pratically vanished after hitting the ground. There is almost no wreckage from that one either. No real proof as to what it was, only a smoking hole.
In both cases, Pentagon and Pennsylvania, the flight data recorders were recovered.
Just another conspiricy story.
I was at home on 9/11 and lived 6ish miles from the Pentagon and heard it blow up. The weirdest unexplained event to me was there was a secondary explosion 20 minutes or so later that was never explained.......
I think this is a bunch of bull. I live in Jersey within eyesite of the towers. I find find that video very offensive. Try to explain it to the families of the vctims on board the plane.
It's fukking bull****! That'a all it is.
It's the product of some low-life, apartment dwelling, maniacal conspiracy theorist with no knowledge about anything pertinent to aircraft crash scene aftermath and investigation.
Show me what's left of this plane after it hits this wall?
http://www.sandia.gov/videos2005/F4-crash.asx
A crash of such high velocity will leave behine nothing but shrapnel and small fragments.
The usual remnants of an aircraft crash are a product of a controlled crash, via a pilot's every efforts to minimize the speeds and forces of impact - this plane was travelling as fast as physically possible to inflict as much damage on the pentagon as managable.
And I love the idiot "eye witness" quotes.
"It sounded like a missle"
"I heard a whoosh, whoosh..."
WTF? How many pedestrian ordinary Joe citizens know what a missile sounds like? A plane travelling at such high speeds near sea-level will yield similar sounds - the sound of millions of pounds of lift - we're not talking about a plane coming in for a gentle landing. Anyone ever sit at the end of a runway with a small plane coming in on very low power - that's airframe noise.
