Toe in - toe out?
Old 05-10-2006 | 03:27 PM
Default Toe in - toe out?
Hi!
I am now rigging twins on my Phantom 25. I have been reccommended to turn the props outward. I will have twin Merc 2.5 EFI SS engines (15 inch mids) spinning for a start labbed Mirage 27 pitch props. Propheight approx. 1 inch below the bottom.
Would you reccommend to mount the engines toe in or toe out. And how much?
Cheeeers, Toffen G
Toffen is offline
Old 05-11-2006 | 08:58 PM
TUFFboat's Avatar
Default Re: Toe in - toe out?
Well this is the next logical question to the rotation one.
There are to different discussions about this...
1- To go fast with the least resistance and assuming that the water comes off the transom with a slight parting angle than you want to have the toe 'in'.
2- Handling, like the skis on your sled toe in and out effect the stability. So, in opposition to the theory of toe-in is faster, the toe-out is easier to steer in a walk. If your boat does not fly high enough to walk then its not an issue.
But none of this matters because you will try a little "in and out" after you deside on rotation which you also tried both ways.
TUFFboat is offline
Old 05-11-2006 | 09:34 PM
Ron P's Avatar
Enjoy the show
1/4 inch toe in. Measured at the bullet and tip of prop shaft. At least that's what worked on my twin OBs.
Be safe out there.
Ron P is offline
Reckless32
Sunsation
16
07-06-2006 06:13 PM
rv
3
05-20-2006 08:30 PM
Monty
10
07-15-2004 01:15 AM
formulaF302
2
06-10-2003 10:55 PM
Raypanic
Powerquest
1
05-22-2002 08:36 PM
