Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Getting rid of Black Streaks And CORRECT buffing pads >
Old 05-10-2006 | 03:29 PM
pkspx's Avatar
Default Getting rid of Black Streaks And CORRECT buffing pads
I have these black streaks all over the boat. Last year I used a product by 3M called Marine Restorer and Wax and then waxed right after that. It seems to bring the boat to a very nice glossy look and was amazing. I used a cloth type pad last time on the buffer but for this year I was alerted to use a foam pad instead. I was also told that it would prevent swirl marks on the hull. Can anyone confirm some of these myths for me? Thanks
pkspx is offline
Old 05-10-2006 | 06:05 PM
glassdave's Avatar
Neno the mind boggler
Default Re: Getting rid of Black Streaks And CORRECT buffing pads
depends on what you are buffing. i have always had best luck with wool on gel coat and foam on painted surfaces. what are you working on?
08 OPA High Points Champion
glassdave is offline
Old 05-10-2006 | 06:30 PM
mopower's Avatar
Toxic FORMULA
If they are the black streaks from your cover and/or snaps that appear after a week or two , I found Windex wipes them right off
mopower is offline
Old 05-10-2006 | 07:09 PM
pkspx's Avatar
It's a Power Quest, gel coat for sure. There are stripes on the hull, blue and green but thats also inside the gel coat.
Yeah thats exaclty the problem but they are almost stained in there. Last year buffing helped alot, boat looked brand new.
pkspx is offline
Old 05-10-2006 | 10:32 PM
Hi
I use Castrol SuperClean, just spray it on and wipe off and after rinse very well. Then apply a good wax, you should be OK for a while
mars is offline
TCH6868
2
06-13-2007 08:57 AM
GregP
05-28-2005 06:30 PM
zog02
04-15-2005 11:15 PM
justinVIP
8
05-02-2004 07:10 PM
