what oil cooler for trs?
Assuming a TRS with B/W tranny, CIG3 it correct. However, most of those came with a bellhousing that had either one or two integral coolers. If it is a TRS using a MerCtrans II, then the cooler is already in the tranny sump. Just be sure those cooler lines have not been capped off because someone installed a later seawater pump that didn't have the port tapped in for that cooler line. --- Jer
What he said......
