old vs new
Old 05-13-2006 | 06:16 PM
TeamSaris's Avatar
Driver-441
Racer
Default old vs new
WOuld an older (198?) Cig cost less in insurance with the same power then a newer strait bottom cug?
TeamSaris is offline
Old 05-13-2006 | 06:39 PM
TeamSaris's Avatar
Driver-441
Racer
Default Re: old vs new
slower old - faster newer
Old 05-13-2006 | 06:45 PM
Too Old's Avatar
I've found that to be true. Probably has to do with declared value????
Too Old is offline
Old 05-13-2006 | 06:48 PM
TeamSaris's Avatar
Driver-441
Racer
or no steps pad or stuff
Old 05-14-2006 | 02:52 AM
Dregsz's Avatar
replacement value on the older boat is much lower then a new boat so Ins is lower.
I'm paying $400 per year on my 89 24' ob through progressive.
With an older boat you can get a solid hull, but get it surveyed to make sure it's solid, and then buy some real motors for it.
If you go much older then 88 you may be getting TRS drives and not Bravos. TRS are solid and can handle power but sit much deeoer then bravos and were rigged deeper back in the day as well, causing more drag, less speed.
I'd be looking for older w newer Bravo refits
good luck
E
Dregsz is offline
