454 build
Old 05-14-2006 | 08:35 AM
Default 454 build
building a gen V 454 motor has been balanced and bored .030 forged speed-pro dome pistons running a crane valve-train and the 420 cam heads a 117cc oval ports with 2.19/1.88 valves since I have switched to a mark IV style valvetrain I am using Mark IV push-rods(lenght is a little longer then the Mark V) comp ratio 8.79-1. I haven't started the motor but if i make the valves to tight will they hit the pistons and lock the motor?
k24u is offline
Old 05-14-2006 | 09:58 AM
FOUNTAINATLAST's Avatar
Default Re: 454 build
The length of the push rod shouldn't matter with your lift. Your still adjusting the rocker arms on the mark IV set-up, were the length becomes a concern is how the rocker arm runs on the valve stem. If your running the stock style stamped steel rockers I wouldn't worry about it, if your running roller rockers you need to pay closer attention to how the rollor tip rides on the valve and get the correct valve geometery.
FOUNTAINATLAST is offline
Old 05-14-2006 | 10:45 AM
I would have checked the piston to valve clearance when I assembled the engine.
1BIGJIM is offline
Old 05-14-2006 | 11:03 AM
formula31's Avatar
Cam timing has a distinct effect on valve to piston clearance. it should be checked when the cam timing is set and a weak checking spring can be used on the valves.
formula31 is offline
Old 05-15-2006 | 11:07 AM
Today I pumped it up to full oil psi and adjusted the valves nothing hit installed the plugs everything seems to be ok now just have to wait for some shine and I will put it in
k24u is offline
Old 05-15-2006 | 12:41 PM
ratman's Avatar
i wouldn't put an engine together without checking piston to valve clearance!!!!!
ratman is offline
RonS
7
05-01-2008 10:56 AM
MILD THUNDER
9
09-08-2005 07:36 PM
jw454
5
12-31-2003 06:27 AM
Wildfire
21
05-28-2003 09:40 PM
mxz800
33
12-17-2002 02:16 PM
