staggering engines? >
staggering engines?
staggering engines?
Old 05-15-2006 | 07:48 AM
glassdave's Avatar
Neno the mind boggler
Default staggering engines?
i am going to be doing stringers and transom at some point on my Scarab III and was thinking about staggering them. i think i have the room, cockpit is big enough i can loose a few inches. what is the biggest reason for staggering? handeling? speed? lower CG? what can i expect in speed gains?
08 OPA High Points Champion
glassdave is offline
Old 05-15-2006 | 07:59 AM
Cool Trips's Avatar
Default Re: staggering engines?
If for no other reason it will be easier to change the plugs
Cool Trips is offline
Old 05-15-2006 | 09:23 AM
The only speed gains will be from a raised X dimension.
You can usually run the props higher, relative to the bottom, because the drives are moved in and down. Since they're going down, relative to the CG, you still have the leverage to trim adequately.
Not sure if I would do it on a 34. I've been on several smaller boats , 31-34', with staggered engines and never liked the ride. Porpoising, funny trim chratersitics. on 38+' boats, I dont think I would even consider side by sides though.
If you're glassing the dtransom, consider raising the drives an inch or more.
Wellcraft used to run the drives, especially TRS, pretty deep. Raising them should be worth a couple mph.
rdoactive is offline
Old 05-15-2006 | 02:28 PM
glassdave's Avatar
thanks guys.
cooltrips . . . yep, that was my first thought. actually came to me while i was putting a starter on it this weekend .
rdoactive thats a good point. i never thought about boat length. this boats never gonna be a speed demon anyway and i dont think i wat to risk any ride issues. i do plan to, at the very least, take some of the X dimension out of it. they are Bravos and yes there pretty deep.
Old 05-16-2006 | 07:14 AM
Scarab3DMC's Avatar
JUST PUT THE 525 S/C's in it and hang on...LOL...
Scarab3DMC is offline
Old 05-16-2006 | 07:39 AM
Ted G's Avatar
Dave, remember that if you raise the X there may be some issues with planing on take off and pushing the bow down in a following sea. Unless you can get some solid numbers and results from someone that did it, this might not be an experiment you'll be happy with. Like you said, it will never be a speed demon with stock power and losing ride quality for an extra 1-2 mph might not be good.
www.cbpba.com
Ted G is offline
LubeJobs42
02-29-2008 10:38 AM
The Menace
Ocean Express
0
10-10-2007 01:15 PM
thedonz
12-16-2003 02:32 AM
jonesj
03-13-2002 02:40 PM
